Techdraw: using metric AND imperial dimensions
Engenia
Post by Engenia »
I have a manual imperial lathe but design in metric, so the drawings I produce need both metric and imperial on many dimensions.
I've searched high and low for including alternate dimensions but have been unsuccessful.
Can it be done?
OS: Ubuntu 20.04.1 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Branch: unknown
Hash: b200801ebcb0d8b9d7a0cd5862de383d9c58b7e7
Python version: 3.8.2
Qt version: 5.12.8
regards
Errol
Re: Techdraw: using metric AND imperial dimensions
Moved to TechDraw forum.
Syres
Post by Syres »
I believe the only quick way to achieve your goal would be to use a macro but this would only to produce decimal imperial dimensions not fractional representations. I'll get some time tomorrow to have a go at writing something.
It may be easier to switch to imperial units and use the macro to convert to the - always decimal - metric system.
domad
Post by domad »
Hi Eugenia,
Is this what you are asking?
Diversified units.png (28.5 KiB) Viewed 4751 times
Engenia
Post by Engenia »
The imperial units I use are decimals, or even just thousandths of an inch. Fractions would be useless on a lathe, at least mine.
Syres, I'd very much appreciate your help with a macro. With a bit of direction, or maybe a tutorial, I may even be able to do it myself.
(I've used Autocad ever since it it was created, and alternate units have been available for as long as i can remember. It is enabled simply with a checkbox. Maybe something similar could be incorporated into Techdraw at some stage in the future.)
Domad. You've caught me mid-post. See above - but fractions aren't much use on machinery. Fine for marking out, but that is about it. I don't use them.
regards
Errol
Engenia
Post by Engenia »
Something like this:
but with the ' " ' suffix. The metric dimension would be covered by the title block details, or simply assumed
regards
Errol
domad
Post by domad »
… he method can be used to indicate multiple measurement systems, at your choice, on the same TechDraw page-.
The method forces TechDraw to show us what we want.
So it's very simple to get, FreeCad is powerful and very flexible, although several things need to be implemented:
- change the unit from the preferences (e.g. in inches);
- on the view on the page with TechDraw enter the dimensions you want to be in inches
- select the size you want to remain in inches
- go to the properties - data and manually write in the "Format spec" property the size expressed in inches (you see in the drawing) you can also write the measurement in mm in brackets
- change the "Arbitrary" property from false to true
you will see that the dimension value will change in the view
- change again the units from the preferences to "metric" or other
- now in the page view enter the dimensions you want to remain in metric decimal.
- if you want to operate the same system mentioned above.
Now in the page view you will see both inch and metric measurements.
I hope I have been sufficiently exhaustive
Good day and good work
domad
Post by domad »
... here is the method applied with three different units...
Diversified units2.png (33.72 KiB) Viewed 4722 times
domad
Post by domad »
.... here is another method with "Draft"
Diversified units3.png (80.05 KiB) Viewed 4690 times
