Texture mapping
Re: Texture mapping
It maps the texture on the inside the environment cube (not sure it is a cube actually), so that all objects will reflect it.
Re: Texture mapping
In other words
meaning the area in the bounding box
Re: Texture mapping
Doesn't matter, if I select the View>Texture mapping and select an image. The solids in the 3D view just turn black.dprojects wrote: ↑Sun Apr 03, 2022 1:34 pm ...The FreeCAD Texture Mapping don't work with faces. It only apply texture for all available objects. But I found it very useful for quick preview.
I am not sure if at FreeCAD there is way to apply texture per face, you know different texture on each face. For sure there is possibility to rotate the face but I didn't look at this yet so deeply.
- Snip macro screenshot-298069.png (122.94 KiB) Viewed 1534 times
Re: Texture mapping
Should not be like this if the texture is valid. However, if you have applied color the texture will not be set, maybe this is why.
EDIT:
Check object property box for color, shape and everything related to color. If this is fine maybe the theme style overwrite default object color. Maybe this is black by default.
Thanks
Darek
github.com/dprojects
Re: Texture mapping
If I would know how to change texture size with the coin library I would add it. But I don't see any option at coin.SoTexture2, anyone?
Thanks
Darek
Re: Texture mapping
What is a valid texture?dprojects wrote: ↑Sun Apr 03, 2022 3:46 pmShould not be like this if the texture is valid. However, if you have applied color the texture will not be set, maybe this is why.
EDIT:
The cube is default from Part workbench Cube primitive. No colors.
Re: Texture mapping
Valid image format, without unexpected characters for the format. Try other texture. Or try to turn off the FreeCAD layout color schema. Maybe this overwrite the object at the FreeCAD system level. The cube should not be black by default. So something is wrong at your FreeCAD installation or configuration.
Thanks
Darek
Re: Texture mapping
You must insert a SoTexture2Transform node before your texture node.
Re: Texture mapping
it has rotation but has also repeat if texture not cover all the cube size? I came across something like REPEAT but I have no idea how to use it yet, this would be useful to apply not full texture but only brick or marble pattern that would be populated on the whole wall for example.Chris_G wrote: ↑Sun Apr 03, 2022 4:06 pm You must insert a SoTexture2Transform node before your texture node.
Thanks
Darek
Re: Texture mapping
I don't know much about textures, but this may be an interesting reading :
http://www-evasion.imag.fr/Membres/Fran ... /ch07.html
