Call for screenshots
Re: Call for screenshots
this is my very fist FreeCAD model. Took whole one day ...
Great try for a 1st model.
(1/2 an hour. )
- CelticTable_SHALM.FCStd
- (70.49 KiB) Downloaded 152 times
- Capture d’écran 2023-01-15 151751.jpg (51.09 KiB) Viewed 40688 times
... trying to understand and build a more symmetric model:
- Celtic_Table_3.FCStd
- FC.20.1
- (46.5 KiB) Downloaded 141 times
- Celtic_Table_2.FCStd
- FC.20.1
- (57.25 KiB) Downloaded 129 times
I think you guys have taken some shortcuts ...
I have refined my model and it is in theory OK - but doesn't update as it should... not sure if it my fault or FreeCAD's...
The parameters are TableHeight, BlattDiameter, BlattThickness, LegThickness, TableSupport. Changing of those doesn't work as expected even though, as far as my geometry goes, it should .
- table05.FCStd
- (56.08 KiB) Downloaded 150 times
- table05.jpg (71.9 KiB) Viewed 40594 times
Just to close this screenshot series: three parameters variations of the table model.
Apparently one have to be careful when garbing references in sketcher - but doing CAD is all about being careful
There is no wood or glass in standard materials , hope will be not long in coming
... arranging the 3 legs of the table at the faces of a cube corner by link-tool:
- Celtic_Table_5.FCStd
- FC.20.1
- (22.77 KiB) Downloaded 139 times
I just finished my first part in Free CAD. It is the base for a tool carousel. The center, threaded hole is for a vertical stud that holds the tiers together and the outer groove is for ball bearing balls.
Very delayed reply, I haven't been active for a while, my current interests/hobbies seem to be gravitating back towards programming. It's in a very alpha state but if you're lucky, it'll integrate Inkscape or The Gimp into the FreeCAD main window, on Linux.Kunda1 wrote: ↑Fri Jun 18, 2021 4:06 amSo amazing! Would you mind atarting up a new thread to keep us updated on your progress?suzanne.soy wrote: ↑Thu Jun 17, 2021 1:19 am Here's a sneak peak at my (pre-alpha) FreeCAD <-> Inkscape integration.
https://github.com/SuzanneSoy/XternalApps.git
It's made to be very generic, so adding support for a new application is usually just ~2h of debugging to find the exact filters to spot the window when it appears, and <10 lines of code. Here are the demo ones included, yes it's that short, 3 apps in 20 lines of code to embed their windows inside FreeCAD:
# app-specific infos:
apps = Apps(
App('Mousepad',
start_command_and_args = ['mousepad', '--disable-server'],
xwininfo_filter_re = r'mousepad',
extra_xprop_filter = lambda processId, windowId, i: True,
tools = []),
App('Inkscape',
start_command_and_args = ['inkscape'],
xwininfo_filter_re = r'inkscape',
extra_xprop_filter = lambda processId, windowId, i: x11prop(windowId, 'WM_STATE', 'WM_STATE') is not None,
tools = [
"myTool.xforms"
# TODO: generate them from """"inkscape --extension-directory"""
App('GIMP',
start_command_and_args = ['env', '-i', 'DISPLAY=:0', '/home/suzanne/perso/dotfiles/nix/result/bin/gimp', '--new-instance'],
xwininfo_filter_re = r'gimp',
tools = []))
- thomas-neemann
wooden data center with heat recovery
- martin.proks
Just something to practice in FreeCad. Mannequin/dummy in full scale (approx. 1850 mm height) as addon to assemblies.
Modelled from scratch.
- mannequin-dummy-1850mm-height.png (38.99 KiB) Viewed 12019 times
Martin Prokš
martin (dot) proks (at) proks-martin (dot) cz
