Modern UI
- HakanSeven12
Re: Modern UI
I removed workbench names from section names. You can see difference at the screenshot.
https://www.patreon.com/posts/48224139
- Section Names.png (220.51 KiB) Viewed 8433 times
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
- MisterMaker
Re: Modern UI
Mesh toolbar look awesome now,really quick fix ! :
- HakanSeven12
Re: Modern UI
Nice
Re: Modern UI
Very nice work.
Though, I come from Inventor and have started with it when they still had vertical "workbenches" on the left side of the screen and never moved on to the GUI design change to have all toolbars at the upper edge of a window/screen that MS favored.
Nowadays with widescreen monitors I always favor having a bit more vertical space, which is why I still run it like this after all those years (and try to set up other CAD tools similarly if possible).
My question thus - can your Modern UI do this too - vertical toolbars/workbenches?
I tried, but had no luck. It seems to be stuck at the top edge of the screen
Is there any setting I miss?
Thanks
Thanks
"Innovation makes enemies of all those who prospered under the old regime, and only lukewarm support is forthcoming from those who would prosper under the new." Nicolo Machiavelli
Re: Modern UI
I've seen vertical workbench toolbars on zolko's (the assembly4 dev's) GUI
as seen in this screenshot
- HakanSeven12
Re: Modern UI
Maybe you want to look at this https://forum.freecadweb.org/viewtopic.php?f=8&t=55779
Re: Modern UI
This is TabBar: https://forum.freecadweb.org/viewtopic.php?t=13368
Re: Modern UI
Ah, thx for the pointer. Much appreciated. Looks more where I would like to go it seemsHakanSeven12 wrote: ↑Tue May 04, 2021 4:10 am Maybe you want to look at this https://forum.freecadweb.org/viewtopic.php?f=8&t=55779
Re: Modern UI
Thanks for this great addon. I found two littles annoyances/bugs.
First, when I start FreeCAD, the icons are not visibles. I need to click on a workbench ribbon to make the buttons visibles.
The second is a downgrade in usability compared to default UI. When I create a sketch with the default UI, the sketcher workbench is switched on and I gain access to the sketcher toolbar. With Modern UI, I have to select the Sketcher ribbon manually when I create a sketch in Part Design. It would be great if Modern UI could automatically switch on the right ribbon based on the current context.
I'm running FreeCAD Link daily 2021.07.17 on Ubuntu 20.04.
Re: Modern UI
This was recently addressed by functionality coded by @chennes. Read more about it on Preferences_Editor#Workbenches
