Dear colleagues, the version of FreeCad I have is as below:
OS: Windows 10
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Locale: Portuguese/Brazil (pt_BR)
The problem is that every time I try to create new material, the program closes. And this happens on all computers with windows 10. Has anyone gone through this to indicate the solution? nothing appears in python.
OBS: Sorry for any bad spelling or grammar. My English language is not good, so I used a translator.
[Solved in 0.19] Problem creating material
- freecad.jpg (179.11 KiB) Viewed 13843 times
- freecad fechando.jpg (212.99 KiB) Viewed 13843 times
Reason: Added [Solved] to thread title
Re: Problem creating material
Would you change the languarge of FreeCAD to english and try again if the problem still exists. You may post the screen again with english languarge. It would be much more easier to repeat this.
bernd
bernd
Also, to benefit from any Materials related updates, OP should also check 0.19_pre as well
Ok bernd / Kunda1.
Gracias/ thank you/ obrigado/ 谢谢啦
I installed version 0.17 and the problem no longer occurred. But I will check version 0.19 and, if applicable, version 0.18 in English.
If I'm not mistaken this is a bug that has existed since the release of 0.18. I think there was a fix already in 0.19, but we failed to backport it to the bug fix releases 0.18.1 to 0.18.4.
Ok mr vocx. I already have the 0.19 version installed and the problem has been solved.
thanks.
thanks.
