Accessing FreeCAD using an external IDE
chenkianwee
Post by chenkianwee »
I would like to access FreeCAD with an external IDE like eric , so instead of scripting in the python console window i will be able to have an external editor ?
how do i set it ?
thanks
kianwee
jriegel
Re: Accessing FreeCAD using an external IDE
Post by jriegel »
If the gui is not up, its easy. Just load FreeCAD as python module.
With the gui up its bit more complicated. Because the event loop is runing.
That means the control gets allways from the event loop to the script.
Werner experimented a bit with such set ups I think....
We could think of some kind of socket we open in FreeCAD which recive
scripting commands and feed it into the event loop. But thats also a big
security hole... :(
Stop whining - start coding!
chenkianwee
yup i tried without the gui and it is working well. hmnnn .... just have to settle for the no gui first or just script in the python console . thanks
chenkianwee
I am trying to write a freecad function with an external IDE eclipse , I have appended the path /usr/lib/freecad/lib , /usr/lib/freecad/mod, /usr/lib/freecad/mod/Part
hoping to get the autocompletion of the various functions and module of freecad. However, it doesnt seem to be working properly. attached below is a screenshot of the autocomplete in eclipse it seems to give me some weird function instead of the normal makeBox() function that i wanted .
jriegel
Post by jriegel »
The question is what can we do about it? Its a question for Eclipse....
It seems that this is not the FreeCAD Part module. What module path is displayed when doing a "print Part"?
chenkianwee
I somehow manage to solve it i guess. so instead of :
import Part
i did :
from FreeCAD import Part
but the autocompletion is still shaky, for e.g. the autocompletion does not work for the Base module and also for the topological data:
Just wondering anyone went thru this issue before. thanks anyway
Maybe Eclipse doesn't like it that you set the sys.path inside the script in order to load FreeCAD there. I guess there must be a way where you can set permanently the path to FreeCAD inside the IDE.
Bad Blue Bull
Post by Bad Blue Bull »
jriegel wrote: Tue Jul 06, 2010 8:35 am If the gui is not up, its easy. Just load FreeCAD as python module.
security hole... :(
Yeah, please I'd like it very much. Simple thing that I want: I use Emacs to write a script file, then send a command to FreeCAD to import this script.
Socket can be closed by default, no problem there.
x64, Slackware 14.2, Linux 4.4.38.
