New libpacks for Windows with Qt5.15, OCC7.5
Re: New libpacks for Windows with Qt5.15, OCC7.5
Where can I find Libpake with python 3.10 or 3.11 ? people are already providing compiled versions with these versions.
https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
then it means that the source code is compatible and it is only necessary to update the libpack?
- adrianinsaval
yes, but python 3.8 is kept around for windows 7 compatibility
would it be too much to ask to maintain two versions of libpack? one with python 3.8 and one with python 3.11
- adrianinsaval
without a compelling usecase yes, you could install the dependencies through conda and compile in a conda env if you really want python 3.11
- MisterMaker
Out of no-where I get this error:
I used the libpack with qt so I don't understand why it needs another dir.
Also it did work the last time I have build Freecad!
So not sure why it stopped working now.
Severity Code Description Project File Line Suppression State
Error CMake Error at cMake/FreeCAD_Helpers/ChooseQtVersion.cmake:79 (message):
Could not find a valid Qt installation. Consider setting Qt5_DIR or
Qt6_DIR (as needed). C:\github repros\FreeCAD_MisterMaker\cMake/FreeCAD_Helpers/ChooseQtVersion.cmake 79
- adrianinsaval
Have you tried making a clean build? or perhaps something got corrupted in your libpack, try redownloading.
- MisterMaker
Omg that was stupid, it had an older settings file open that was not in the repro directory. And so it couldn't find the libpack, and it did gave the libpack warning but only in console in the warning dialog it gave the QT warning.
Lessons learned!
0.21 looks good
Lessons learned!
0.21 looks good
Looking for a python 3.11 one.
Another program doesn't works with 3.8
