New libpacks for Windows with Qt5.15, OCC7.5
apeltauer
Re: New libpacks for Windows with Qt5.15, OCC7.5
Post by apeltauer »
HI all,
i have created a new libpack with occ 7.5.3...
https://github.com/apeltauer/FreeCAD/re ... ack_12.5.4
Tests are welcome. Please add issues to the issue list in github:
https://github.com/apeltauer/FreeCAD/issues
Thanks....
uwestoehr
Post by uwestoehr »
Many thanks!
The Libpack works fine. I only found 2 minor issues and reported them.
falviani
Re: Help! - New libpacks for Windows with Qt5.15, OCC7.5
Post by falviani »
Hello all,
My current (broken) build from source:
Version: 0.20.27081 (Git)
Hash: c0c4ae40a5f7f44fcc601645988b2aa1fed5f942
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I did a pull this morning, then cleaned before building, so it's up to date.
Dumb question here - I haven't changed my build configuration in forever, and I can't remember how to update the libpack that's built against. Could some kind soul post simple instructions here. I am doing a little development of a workbench, but I am not touching FreeCAD itself - I just want to keep up to date.
Thanks in advance!
Frank Alviani
falviani
Post by falviani »
Hello All,
I think I downloaded the wrong version. My bad. :oops:
Frank Alviani
falviani
Re: Errors in New libpacks for Windows with Qt5.15, OCC7.5
Post by falviani »
I have found errors and warnings when building with the latest libpack (FreeCADLibs_12.5.4_x64_VC17a) and put an entry in the issue list in GitHub as requested. The info for my latest build is:
Version: 0.20.27133 (Git)
Hash: b3e52226fec48d58f4acca4f9699e52ed2e4c003
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
The github entry includes a file with the error output of my latest build - hopefully that will help.
GeneFC
Post by GeneFC »
falviani wrote: Thu Jan 20, 2022 5:13 pm I have found errors and warnings when building with the latest libpack (FreeCADLibs_12.5.4_x64_VC17a)
I am not sure which libpack your are using, but I do not think it is the correct one.
Here is the "about" info from my latest (successful) compile a couple days ago.
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.20.27095 (Git)
Branch: Master
Hash: 74fe1fa4db96ce9ba63a156515ddf816117c7a6e
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Gene
Syres
Post by Syres »
Unfortunately it was confirmed recently that two LibPacks had the same name but only one should be used and it is located at https://github.com/apeltauer/FreeCAD/re ... ack_12.5.4
Hopefully now the version control will be done in one place from now on.
falviani
Post by falviani »
I went to the given link and downloaded the file. Rebuilding with the new libpack gave the same errors and warnings. :shock:
What else could I be doing wrong?
-Frank
GeneFC
Post by GeneFC »
How are you getting an OCC version of 7.5.0 with the correct libpack?
Something is not adding up.
Gene
chennes
Post by chennes »
Are you using the COPY_* options in cMake?
Chris Hennes
Pioneer Library System
