New libpacks for Windows with Qt5.15, OCC7.5
falviani
Re: New libpacks for Windows with Qt5.15, OCC7.5
Post by falviani »
GeneFC - I searched for Copy in the CMake interface and found nothing. This is the arrangement I've been using for over a year.
CHennes - I went to the link given above by SRes (https://github.com/apeltauer/FreeCAD/re ... ack_12.5.4) and download it. I updated the FREECAD_LIB_DIR setting to match.
The title is:
Libpack 12.5.4 for Windows VS2019, Qt5.15, Python3.8, OCC7.5.3
The description in GitHub is:
FreeCAD LibPack Version 12.5.4 debug/release with
Visual Studio 2019
OpenSSL 3.0.0
LibSSL 1.1.1l
Curl
Qt 5.15.2
PySide2 build against Qt 5.15
Coin3D 4.0
Pivy
Python 3.8
OpenCascade 7.5.3 with Fillet fix from https://gitlab.com/blobfish/occt provided by Chris Hennes
Boost 1.67 (including the debug files build against python_d.exe)
I don't know what else to tell you. If you can point me to some other useful information I'll go hunt it down.
Thanks in advance!
chennes
Post by chennes »
falviani wrote: Thu Jan 20, 2022 11:35 pm I searched for Copy in the CMake interface and found nothing.
Please see the CMake variables section on the wiki (https://wiki.freecadweb.org/Compile_on_Windows). In particular,
FREECAD_COPY_DEPEND_DIRS_TO_BUILD Copies depending libraries needed to execute the FreeCAD.exe to the build folder. See also section Running and installing FreeCAD.
Note: the options FREECAD_COPY_XXX only appear if the libraries were not already copied. So when you change to another LibPack version, it is important to delete all folders in your build folder, except of the LibPack folder. In CMake delete the cache and start as if you compile for the first time and you will get the FREECAD_COPY_XXX options. OFF
FREECAD_COPY_LIBPACK_BIN_TO_BUILD Copies the LibPack binaries needed to execute the FreeCAD.exe to the build folder. See also section Running and installing FreeCAD. OFF
FREECAD_COPY_PLUGINS_BIN_TO_BUILD
Chris Hennes
Pioneer Library System
GeneFC
Post by GeneFC »
I always start with a completely new build folder and a completely fresh copy of everything. I have tried re-using various short-cuts and overwrites and I always take more time to fix leftover garbage than to spend the 2 minutes extra to do a clean build. In particular CMake seems to bury a number of ini-type files that can cause problems.
If someone is trying to build-debug-build-debug, etc it might be different, but for just an ordinary build intended to be used, and not further developed, go for clean.
Gene
uwestoehr
Post by uwestoehr »
falviani wrote: Thu Jan 20, 2022 8:24 pm I went to the given link and downloaded the file. Rebuilding with the new libpack gave the same errors and warnings. :shock:
What else could I be doing wrong?
As I already stated here in your bug report:
https://github.com/apeltauer/FreeCAD/issues/23
Everything is basically working fine for you. You only run into a bug in FreeCAD I fixed already. Please checkout master and try again.
In every case strictly follow https://wiki.freecadweb.org/Compile_on_Windows
akimfidz
Post by akimfidz »
I recommend to use the sources of the older netgen you used once to build with OCC 7.3 and rebuild it using OCC 7.4. The build failures of the netgen plugin is not because of API changes of OCC but of the newer netgen version. There e.g. the class OCCRefinementSurfaces has been removed and some global variables have become class variables.
uwestoehr
Post by uwestoehr »
akimfidz wrote: Fri Jan 28, 2022 7:32 am I recommend to use the sources of the older netgen you used once to build with OCC 7.3 and rebuild it using OCC 7.4.
What are you talking about? Where do you see Netgen build failures?
Note that we freeze in FreeCAD the Netgen support to the version that is distributed with the latest LibPack. You cannot use another Netgen version.
So please take the current LibPack as it is and follow strictly
and you can build FreeCAD successfully.
Before the next major FreeCAD release we will upgrade to a newer Netgen version and also to OCC 7.6, for now we decided to stay with the Netgen current version
apeltauer
Post by apeltauer »
Hi all,
i am working on providing a new libpack with occ 7.6.1.
In this step i also could upgrade netgen. Any suggestion what version is compatible with the current master?
Any other suggestions or wishes can be added to my github issue list (https://github.com/apeltauer/FreeCAD/issues)
uwestoehr
Post by uwestoehr »
apeltauer wrote: Wed Mar 16, 2022 7:16 am i am working on providing a new libpack with occ 7.6.1.
Besides what I wrote here: https://github.com/apeltauer/FreeCAD/issues/26
- Python should be updated to the latest version of the 3.9.x series
Concerning Netgen, I fear we have to act the same as for the 0.19 release: You provide a LibPack and then we need to check how our code needs to be adapted. Then we keep the Netgen version stable for the while lifetime of FC 0.20.
uwestoehr wrote: Wed Mar 16, 2022 12:20 pm - Python should be updated to the latest version of the 3.9.x series
I personally don't mind but I think this means dropping support for windows 7 in the installer right? AFAIK only up to 3.8 runs there.
Syres
Post by Syres »
There seems to be some differing standards going on here, Linux platform for FC is supported back to Python 3.6.x and throughout the 0.20 development cycle Win 7 users have been giving valuable feedback. Now at the last minute the intention is to completely disregard them, really bad karma IMHO.
