[ Architecture Masterpiece ] Villa Savoye FC Model
paullee
Re: [ Architecture Masterpiece ] Villa Savoye FC Model
Post by paullee »
[ Pseudo-Tutorial - 1 ... Pseudo-Tutorial - 3 ]
Pseudo-Tutorial - 2
Sketches as Window Layout
  1. As explained in last section, the model use mostly Sketches as Base of ArchWall instead of Draft Line or Wire etc
  2. Sketch is used as Base of ArchWindow in its original Arch design
  3. Again, Sketch's MapMode / Attachment Offset function is used to place the disposition of the Windows relative to each Flor Plan / Sketch
  4. Click Window Sketch MapMode "...", Select GF / 1F / 2F Sketch in the 1st Reference, Object XY in Attachment Mode, and appropriate setting-out in x/y/xz-Direction and rotation in x/y/z-axis
  5. The Windows Sketch is now placed against the GF / 1F / 2F Sketch Relatively
  6. Window object is created against these Window Sketches and select the appropriate Wall as their hosts
  7. Now the Floor Layout + Windows Sketches / Model are conceived / would move as a whole
To be continued ...
Step 1 ~ 2 : 1F Window Sketches Layout
Screenshot from 2020-03-03 03-01-16.png (187.52 KiB) Viewed 4017 times
Step 3 ~ 5 : Setting MapMode / Attachment Offset of Window Sketches against each Floor Layout Sketch
Screenshot from 2020-03-03 03-01-51.png (201.55 KiB) Viewed 4017 times
Step 6 ~ 7 : Window Objects based on 'attached' to Walls Objects and would moved as a whole
Screenshot from 2020-03-03 02-59-51.png (295.27 KiB) Viewed 4017 times
paullee
Post by paullee »
Screenshot from 2020-03-03 03-14-28.png (222.5 KiB) Viewed 4011 times
Screenshot from 2020-03-03 03-15-52.png (273.17 KiB) Viewed 4011 times
Updated model uploaded to github
This is such a cool test case. Thanks paullee for keeping this thread updated and helping to improve FreeCAD this way.
fc_tofu
Post by fc_tofu »
paullee wrote: Mon Mar 02, 2020 7:06 pm ...
[*]Now the Floor Layout + Windows Sketches / Model are conceived / would move as a whole
This is fantastic. But I just cannot implement it on my machine. Could you make a little sample file (1 window+1 wall) for me, Please?
BTW, when using attachment mode in ArchWB, the viewport clipping plane always shrinked, and part of modle disappeared. What's your solution?
kisolre
Post by kisolre »
View/Zoom/Fit all
paullee
Post by paullee »
fc_tofu wrote: Wed Mar 04, 2020 4:18 pm
[ Pseudo-Tutorial - 1 ... Pseudo-Tutorial - 2 ]
OK
Psuedo-Tutorial 3
Window based on Sketch Attached to Base of Wall :)
  • Window Sketch
    . . v
    Wall Sketch
    ( see Mapmode / Attachment parameters)
    Screenshot from 2020-03-06 02-41-08.png (226.54 KiB) Viewed 3892 times
  • Wall + Window
    Screenshot from 2020-03-06 02-40-51.png (259.9 KiB) Viewed 3892 times
  • Dependency Graph
    Screenshot from 2020-03-06 02-41-21.png (271.46 KiB) Viewed 3892 times
  • Wall Sketch - X-placment moved to 1000, Window Sketch + Window + ArchWall all Moved as a Whole
    Screenshot from 2020-03-06 02-49-14.png (261.5 KiB) Viewed 3892 times
Test_ ArchWall_ Sketch Attached on Sketch_ 01.FCStd
(19.47 KiB) Downloaded 111 times
fc_tofu
Post by fc_tofu »
Thank you, I got it and need more time to practice.
bitacovir
Post by bitacovir »
I included references to your model in a Wiki with links to Architecture FreeCAD models.
https://wiki.osarch.org/index.php?title ... in_FreeCAD
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
paullee
Post by paullee »
bitacovir wrote: Thu Apr 09, 2020 6:20 pm I included references to your model in a Wiki with links to Architecture FreeCAD models.
Thanks! I just remember there are a lots of house models studies @Yorik and @Regis did (can't find all of them atm).
Some of them are shown in the Architecture Works in FreeCAD e.g. the Elemental---Quinta-Monroy, the model is at Gihub Github - Elemental---Quinta-Monroy
EDIT -
And a wiki page on Architectural Tutorials
bitacovir
Post by bitacovir »
paullee wrote: Sun Apr 12, 2020 12:07 am e.g. the Elemental---Quinta-Monroy, the model is at Gihub Github - Elemental---Quinta-Monroy
It is already included in the list. Also the wikilab project by Yorik.
::bitacovir::
