Page 1 of 2
How to Constrain Custom Length Property With Lower and Upper Bound?
Posted: Fri Jan 24, 2020 2:01 am
by gbroques
I have a
scripted object with custom length property using
App::PropertyLength, and I'd like to set a lower and upper bound.
According to
this wiki page:
A complete list of property attributes can be seen in the PropertyStandard C++ header file. For instance, if you want to allow the user to enter only a limited range of values (e.g. using PropertyIntegerConstraint), in Python you will assign a tuple containing not only the property value, but also the lower and upper limit as well as the stepsize, as below:
prop = (value, lower, upper, stepsize)
Here is some code I'm trying:
class SomeObject:
def __init__(self, obj):
self.Type = 'SomeObject'
obj.Proxy = self
# Length property
obj.addProperty('App::PropertyLength', 'Length', 'Base', 'Length tooltip')
obj.Length = (300, 100, 1000, 1) # I want a length property that defaults to 300, and can be between 100 - 1000 with a step-size of 1.
I get the following error:
File "/home/g/Projects/ose-universal-axis-macro/universal_axis/universal_axis_model.py", line 26, in __init__
<type 'exceptions.AttributeError'>: Attribute (Name: Length) error: 'wrong type as quantity: tuple'
I see
App::PropertyLength extends
App::PropertyQuantityConstraint. Do I need to use some other property type to achieve the desired effect?
FreeCAD version information:
OS: Linux
Version: 0.18.16093 (Git)
Build type: Unknown
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
Python version: 2.7.12
Qt version: 4.8.7
OCC version: 7.0.0
Re: Constrain custom length property with lower and upper bound?
Posted: Fri Jan 24, 2020 4:44 am
by vocx
gbroques wrote: ↑Fri Jan 24, 2020 2:01 am
Qt version: 4.8.7
You should use Python 3 and Qt5, as Python 2 and Qt4 are obsolete.
As for your particular issue, I went to
PropertyStandard.h as it was mentioned in your post.
https://github.com/FreeCAD/FreeCAD/blob ... #L544-L552
/** setting the boundaries
* This sets the constraint struct. It can be dynamcly
* allocated or set as an static in the class the property
* blongs to:
* \code
* const Constraints percent = {0.0,100.0,1.0}
* \endcode
void setConstraints(const Constraints* sConstrain);
Maybe you need to
obj.Length.setConstraints(lower, upper, step)
Posted: Fri Jan 24, 2020 12:20 pm
by DeepSOIC
vocx wrote: ↑Fri Jan 24, 2020 4:44 am
Maybe you need to
Unfortunately, .Length attribute returns a Quantity (pretty much just a number). It does not return a reference to the property object; as far as I know, nothing does, and it would be really nice to have someone make that happen.
I want to do it, but I can't now (I have too much other stuff to worry about).
Posted: Sat Jan 25, 2020 9:41 pm
by gbroques
Both
App::PropertyIntegerConstraint and
App::PropertyFloatConstraint (defined in
PropertyStandard.h) work when setting bounds like so:
x = obj.addProperty('App::PropertyFloatConstraint', 'Length', 'Base', 'tooltip')
obj.Length = (300.0, 100.0, 1000.0, 1.0)
DeepSOIC is right. When using
App::PropertyLength and accessing the property (i.e. obj.Length), you get a
Quantity object.
I'm assuming any property extending
PropertyQuantityConstraint would also suffer from not being able to set bounds:
- PropertyLength
- PropertyArea
- PropertyVolume
- PropertyAngle
DeepSOIC, can you propose how the Python API might look, and provide guidance to how one could accomplish this?
I'm new the FreeCAD codebase, but familiar with C++ / Python, and willing to get my hands dirty.
Personally, I think the Python API for setting bounds of all properties should be similar to avoid confusion.
Unless someone knows of a different way to have a property with units and custom bounds?
Re: How to Constrain Custom Length Property With Lower and Upper Bound?
Posted: Sat Jan 25, 2020 10:04 pm
by DeepSOIC
gbroques wrote: ↑Sat Jan 25, 2020 9:41 pm
Like so:
obj.Property("Length").UpperLimit = somethingsomething
That is,
.Property("Length") should give access to property object.
As for bindings, it is tricky in that the lifetime of property objects is managed by C++ in a way that is somewhat incompatible with python. The easiest solution (IMO) would be to have a PropertyRef py-binding object, that holds a python reference to host object + the name of the property, and looks up the actual property every time something is accessed. It's slower than it can be, but I think it shouldn't be a big deal.
Posted: Sat Jan 25, 2020 10:09 pm
by DeepSOIC
a viable alternative is to copy the way it is done for DocumentObject.
DocumentObject creates a py twin, and has a reference to the twin, keeping it alive as long as the object is alive. Then, when the object is deleted, it sets the twin into a zombie state, where accessing anything raises an error. And releases the reference. If there are no references remaining, the twin is deleted. But if there are, the twin remains in this zombie state.
Posted: Sat Jan 25, 2020 10:25 pm
by gbroques
DeepSOIC wrote: ↑Sat Jan 25, 2020 10:04 pm
Like so:
That is,
What you're proposing is a
breaking change, right? Shouldn't we try to minimize breaking changes?
What about a new property called
App::PropertyLengthConstraint that works as you suggest, and gives a reference to the property object?
(Also, thanks for the pointers on the possible implementation
Posted: Sat Jan 25, 2020 10:39 pm
by DeepSOIC
gbroques wrote: ↑Sat Jan 25, 2020 10:25 pm
What you're proposing is a breaking change, right?
No. .Length attribute remains, and still returns the value, not the object.
Posted: Sat Jan 25, 2020 10:41 pm
by DeepSOIC
What about a new property called App::PropertyLengthConstraint that works as you suggest, and gives a reference to the property object?
What about all other properties, then? There's more useful stuff about having the object. One example is a "touched" flag, which is only available in c++ so far (I think)
Posted: Sat Jan 25, 2020 11:03 pm
by gbroques
DeepSOIC wrote: ↑Sat Jan 25, 2020 10:39 pm
Gotcha. I was misunderstanding.
You're saying to add a new mechanism to get the entire property object.
Maybe a new
Property attribute on
Part::PartFeature or parent class of it.
There is a
getPropertyByName method on
Part::PartFeature already. So naming it
Property might be confusing if we don't properly distinguish the two.
DeepSOIC wrote: ↑Sat Jan 25, 2020 10:41 pm
Yes, you have a good point. There will likely be other useful things on property object we want access to like the
touched flag.
