PR#2862: Configuration Table using Spreadsheet
hasecilu
Re: PR#2862: Configuration Table using Spreadsheet
Post by hasecilu »
Is it possible to use strings in a configuration table?
A usecase would be to create a configuration table in which a column of data have metric sizes (i.e. M5, M6, M8, etc) to be used with the Hole feature of the PartDesign WB. For the moment the Hole feature in the Size drop-down list don't accept Expressions, but if it does it could retrieve the "Mx" string and update the bore, thread, countersink sizes accordingly.
realthunder
Post by realthunder »
hasecilu wrote: Wed Jul 06, 2022 10:09 pm Is it possible to use strings in a configuration table?
Yes sure. Almost all properties can be bound by expression. It's just that not all of them are exposed to the editing task panel. Use property editor to find the 'ThreadSize' property of the hole, right click the property name and choose 'Expression...'.
hasecilu
Post by hasecilu »
Thanks for your answer and sorry for the late response, afk.
I have follow the steps and it worked, I didn't know about this feature. Last days I have been modelling some parts for the FreeCAD library and this is very helpful. Also now I remember that is possible to attach Expressions to Body names...
MSOlsen65
Post by MSOlsen65 »
OS: openSUSE Tumbleweed (KDE//usr/share/xsessions/plasma5)
  * Assembly4 0.12.5
  * offline-documentation 1.0.0-alpha
  * Help 1.0.3
  * symbols_library
  * CubeMenu
HELP!! :? I know this thread is aimed mainly at developers and I am merely a user. However, it is also the only resource I could find to set up configuration tables for Variant Links (directed here from the FC Documentation site).
I am very confused and have many questions. Is there perhaps a tutorial or video aimed at users for Variant Links?
What I am attempting to model is a tool chest system. It has 9 variants of drawer sizes and 4 variants of drop front doors. Here is my working concept drawing:
Rolling Tool Chest Design Concept.pdf
(651.1 KiB) Downloaded 127 times
What I would like to do is create one complete drawer from five parts then vary the dimensions (i.e. drawer_width and drawer_height) to create the the parts needed for the different drawer sizes.
Parts List :
  • front
  • back
  • bottom
  • left_side
  • right_side (mirror of left)
Key dimensions:
  • drawer_width (left to right)
  • drawer_height (top to bottom)
  • drawer_depth (front to rear - constant at 535 mm)
  • material_thickness (constant at 13 mm for all parts)
So far I am lost on even creating a configuration table in a spreadsheet. I also need to know how to turn these parts into different size drawer assemblies, which must then be placed within their corresponding chest section. Asembly4 only allows for one assembly model per file, and I need 9 different drawer models.
The drop front doors present a similar problem, 4 doors all of the same width but varying in height. Each made of the same 3 parts: rail x 2, stile x 2, and a panel. All the rails will be identical, but the stile and panels vary in height as the door varies. Modeling the parts gives me 4 different assembly models when I am only allowed 1 per file.
The trivial answer is to simply create a file for every assembly variation, but I was hoping for a "more elegant and efficient" method by using Variant Link, and a great deal fewer redundant parts.
Thank you all so much for your precious time and help.
Sincerely,
Michael S. Olsen
Electrical Engineer & Joiner
FCuser2019
Post by FCuser2019 »
Hello, I hope this example will be of help to you:
viewtopic.php?p=583483#p583483
hotqin888
Post by hotqin888 »
The `Configuration Table` feature is fantastic. I'd like to use this feature with full parameters, e.g. in headless modehttps://wiki.freecad.org/Embedding_FreeCAD, assign a value('config3') to the table B3 cell via python code, and then the cell(C3~F3) of data can be switched like a Configuration Table
Thank you!
hotqin888
Post by hotqin888 »
hotqin888 wrote: Thu Mar 21, 2024 9:30 am The `Configuration Table` feature is fantastic. I'd like to use this feature with full parameters, e.g. in headless modehttps://wiki.freecad.org/Embedding_FreeCAD, assign a value('config3') to the table B3 cell via python code, and then the cell(C3~F3) of data can be switched like a Configuration Table
Thank you!
I got it.
Input "=dbind(Body.Configuration.All)" in B3,then right click on the B3,click edit mode——combobox,select persistent.
hotqin888
Can the configuration table support column direction parameters?
Post by hotqin888 »
For example, if I have multiple sets of parameters, and I want to use the configuration table function to switch column data groups. At the moment, it seems to be switching by row. Because the amount of data exceeds a dozen, it is difficult to organize the data in rows, so you need to use the mouse to click and hold the scroll bar below to move left and right, and scrolling up and down with the scroll wheel can be convenient to view multiple data. Thank you very much.
