Grid, IfcGrid is imported with wrong placement
bernd
Post by bernd »
attached a simple example file.
See grid in IFC++ and in FreeCAD. In FreeCAD it misses the grid placement. I will give more informations in a separate post.
OS: Debian GNU/Linux 10 (buster) (KDE//usr/share/xsessions/plasma)
Version: 0.19.18515 (Git)
Build type: Unknown
Hash: 90fad8180fac6d514048e3ca9179c9705a736b82
Python version: 3.7.3
Qt version: 5.11.3
ifcgrid_example.ifc
(43.26 KiB) Downloaded 143 times
bernd
Re: Grid, IfcGrid is imported with wrong placement
Post by bernd »
attached the important entities
#134= IFCGRID('0GRU0LrWCHwPzj636$u4oZ',#11,'Grid CW',$,$,#68,#132,(#104,#108,#112,#116,#120,#124),(#72,#76,#80,#84,#88,#92,#96,#100),$);
#68= IFCLOCALPLACEMENT(#60,#67);
#60= IFCLOCALPLACEMENT($,#59);
#59= IFCAXIS2PLACEMENT3D(#56,#58,#57);
#56= IFCCARTESIANPOINT((-18.003500,-83.838410,0.));
#57= IFCDIRECTION((1.,0.,0.));
#58= IFCDIRECTION((0.,0.,1.));
#67= IFCAXIS2PLACEMENT3D(#66,#39,#37);
#66= IFCCARTESIANPOINT((2942.607195,68435.881370,0.));
#39= IFCDIRECTION((0.,0.,1.));
#37= IFCDIRECTION((1.,0.,0.));
It is not difficault to fix. Since in FreeCAD all axes are in one grid object we just need to set the placement of this grid object. The cool thing is, with this we have set up the grid in FreeCAD the same way as in the ifc file.
I was wondering if there is some code in Arch already to read IfcLocalPlacement and create a FreeCAD placement from it?
yorik wrote: ping
bernd
Post by bernd »
bernd
Post by bernd »
eventually the fix was quite easy because there is a method to get a FreeCAD placement from a IFC placement, thanks to Yorik :D
git commit a431cf7
yorik
Post by yorik »
great!! thanks for the fix!
pdpb59
Post by pdpb59 »
bernd wrote: Fri Oct 11, 2019 7:59 pm
How do I manage to assign the Axis system to the ifcGrid? I can not find a connection?
Peter
bernd
Post by bernd »
pdpb59 wrote: Thu Nov 03, 2022 7:18 pm
Peter
viewtopic.php?p=661374#p661374
