TechDraw: The People's Republic of China Templates A serial
felixlee868
Post by felixlee868 »
Hi
I worked for the People's Republic of China State standard template files. The files only for A serial page size.
please pull branch felixlee from. https://www.95839.com/freecad.git/
Re: TechDraw: The People's Republic of China Templates A serial
Following the link I get an empty page.
felixlee868
use git clone command.
git clone https://www.95839.com/freecad.git
git checkout origin/felixlee -b zhcn
PrzemoF
Post by PrzemoF »
@felixlee868: can you upload it to github and make a pull request? That's the standard way of adding code to FreeCAD. The pull request then goes through a series of automated builds and tests to make sure your changes doesn't break existing code.
Please let me know if you need more detailed info how to do it.
felixlee868
Ok
The GitHub URL is: https://github.com/felixlee868/freecad
Please checkout branch: felixlee
please merge to master branch for the files
Due to my git repo server in China, the network not so faster. I have pull the branch to my GitHub account.
PrzemoF
Post by PrzemoF »
Great! Now you can login to your github account and make the pull request. Switch to your branch and click button "New pull request". That will trigger the code tests.
felixlee868
Hi
I have merge branch felixlee to master on https://github.com/felixlee868/freecad
felixlee868 wrote: Wed Jul 03, 2019 12:57 pm I have merge branch felixlee to master on https://github.com/felixlee868/freecad
This is not what @sgrogan meant.
You keep the branch on your fork and you add FreeCAD/FreeCAD as a remote.
Then you submit a PR to FreeCAD/FreeCAD
Checkout https://www.freecadweb.org/wiki/Source_ ... ut_Remotes
felixlee868
It is hard for old man to found the git function on GitHub. I have done the next steps:
1 fork project from FreeCAD/FreeCAD
2 upload my added files and directory in FreeCAD/src directory
3 create pull request on GitHub
I don't know if the process is ok for push my patch for FreeCAD project.
