updating a sketch's constraints from python
fourchette
Post by fourchette »
I am thinking of making a 2DOF cable robot. Something like a polar graph robot (such that draws on wall), but using 4 cables insteads of 2.
I think I have the mathematical model right. It shouldn't be too hard to make a motor algorithm to drive it.
However, before I actually start designing parts, cutting/milling/printing/ordering/etc. I would like to check that my model works.
In essence, I could just make a sketch in freecad of the geometry. Then I want to create a script that update some of the sketch distance and angular constraints in a loop while measuring some other distance/angle and check that they do match my expected values.
=> observe the "animated" sketch and hope that it works as I intend it to work
Reading the python manual of freecad, I see stuff about UI, about parts, about meshes and draft workbenches, but i do not see anything about sketches.
How can I modify a sketch dimension constraint from python, recompute the sketch model, and measure a given distance of a segment in that sketch from a python script?
If I have to, i am fine creating the sketch entirely from python.
I just found this python sniuppet related to sketch => https://www.freecadweb.org/wiki/Macro_Shake_Sketch
but this is no example of constraint values manipulation (unless i'm mistaken)
thanks
Re: updating a sketch's constraints from python
Show the Python console and change the value of a consraint. Now you can see in the console the corresponding python code ,e.g something like
App.ActiveDocument.Sketch.setDatum(9,App.Units.Quantity('25.000000 mm'))
If you want to measure something else you can use a so called driven constraint (shown in blue), and read its value.
fourchette
great! i found it.
you can find the id of a given segment, by turing it blue or not, and then appears the "App.ActiveDocument.Sketch.toggleConstruction(10)"
can you please elaborate on
what is the command to issue exactly?
I see many items/objects/functions in App.ActivreDocument.Sketch but nothing that contains "distance" or "length"
>>> dir(App.ActiveDocument.Sketch)
['Attacher',
'AttacherType',
'AttachmentOffset',
'AxisCount',
'ConstraintCount',
'Constraints',
'Content',
'DeleteUnusedInternalGeometry',
'Document',
'ExposeInternalGeometry',
'ExpressionEngine',
'ExternalGeometry',
'Geometry',
'GeometryCount',
'InList',
'InListRecursive',
'Label',
'MapMode',
'MapPathParameter',
'MapReversed',
'MemSize',
'MissingLineEqualityConstraints',
'MissingPointOnPointConstraints',
'MissingRadiusConstraints',
'MissingVerticalHorizontalConstraints',
'Module',
'Name',
'OpenVertices',
'OutList',
'OutListRecursive',
'Placement',
'PropertiesList',
'Shape',
'State',
'Support',
'TypeId',
'ViewObject',
'__class__',
'__delattr__',
'__dir__',
'__doc__',
'__eq__',
'__format__',
'__ge__',
'__getattribute__',
'__gt__',
'__hash__',
'__init__',
'__init_subclass__',
'__le__',
'__lt__',
'__ne__',
'__new__',
'__reduce__',
'__reduce_ex__',
'__repr__',
'__setattr__',
'__sizeof__',
'__str__',
'__subclasshook__',
'addConstraint',
'addCopy',
'addExtension',
'addExternal',
'addGeometry',
'addMove',
'addProperty',
'addRectangularArray',
'addSymmetric',
'analyseMissingPointOnPointCoincident',
'autoRemoveRedundants',
'autoconstraint',
'calculateAngleViaPoint',
'calculateConstraintError',
'carbonCopy',
'changeAttacherType',
'changeConstraintsLocking',
'convertToNURBS',
'delConstraint',
'delConstraintOnPoint',
'delExternal',
'delGeometry',
'deleteAllConstraints',
'deleteAllGeometry',
'deleteUnusedInternalGeometry',
'detectMissingEqualityConstraints',
'detectMissingPointOnPointConstraints',
'detectMissingVerticalHorizontalConstraints',
'dumpContent',
'dumpPropertyContent',
'enforceRecompute',
'exposeInternalGeometry',
'extend',
'fillet',
'getAllDerivedFrom',
'getAxis',
'getDatum',
'getDocumentationOfProperty',
'getDriving',
'getEditorMode',
'getGeometryWithDependentParameters',
'getGlobalPlacement',
'getGroupOfProperty',
'getParentGeoFeatureGroup',
'getParentGroup',
'getPaths',
'getPathsByOutList',
'getPoint',
'getPropertyByName',
'getPropertyNameOfGeometry',
'getTypeIdOfProperty',
'getTypeOfProperty',
'getVirtualSpace',
'hasExtension',
'increaseBSplineDegree',
'isDerivedFrom',
'isPointOnCurve',
'makeMissingEquality',
'makeMissingPointOnPointCoincident',
'makeMissingVerticalHorizontal',
'modifyBSplineKnotMultiplicity',
'moveDatumsToEnd',
'movePoint',
'positionBySupport',
'purgeTouched',
'recompute',
'removeProperty',
'renameConstraint',
'restoreContent',
'restorePropertyContent',
'setConstruction',
'setDatum',
'setDatumsDriving',
'setDriving',
'setEditorMode',
'setExpression',
'setVirtualSpace',
'solve',
'supportedProperties',
'toggleConstruction',
'toggleDriving',
'toggleVirtualSpace',
'touch',
'trim']
fourchette
forget it. i think I found it
>>> App.ActiveDocument.Sketch.getDatum(10)
80 mm
i'll be playing with this and report if i have further questions
fourchette
After a bit of struggle (first script in freecad :D), i managed to do what I wanted.
=> calculate A, B and C constraints, then recompute the model.
here's a code snippet
def update_model(x, y):
    (a, b, c, d) = get_abcd(x, y, w, h, w0, h0)
    print(a, b, c, d)
    # a
    App.ActiveDocument.Sketch.setDatum(a_constraint_id,App.Units.Quantity(str(a)+' mm'))
    # b
    App.ActiveDocument.Sketch.setDatum(b_constraint_id,App.Units.Quantity(str(b)+' mm'))
    # c
    App.ActiveDocument.Sketch.setDatum(c_constraint_id,App.Units.Quantity(str(c)+' mm'))
    # recompute
However, the animation kinda flickers. It seems to me Freecad does
update A
recompute
update B
recompute
update C
recompute
a video of the behavior => https://drive.google.com/open?id=1i4BI- ... L5sRoe2cXt
How can I get rid of the intermediary "recompute" (force freecad to update the model only when i say so, instead of anytime it think there needs a refresh?)
my Freecad environment:
OS: Windows 7
Version: 0.18.16110 (Git)
Branch: (HEAD detached at upstream/releases/FreeCAD-0-18)
Hash: f7dccfaa909e5b9da26bf50c4a22ccca9bb10c40
Python version: 3.6.6
Qt version: 5.6.2
Locale: French/France (fr_FR)
openBrain
Post by openBrain »
App.ActiveDocument.RecomputesFrozen = True
Think about unfreezing at the end of your macro. ;)
fourchette
it goes faster. but i still observe that the sketch tries to update itself before my call to App.ActiveDocument.recompute()
one way to observe it is to give A a distance that is too high before i update constraints B and C => i then receive ValueError: Invalid constraint index: 25
is it a known limitation of am i missing something?
openBrain
Post by openBrain »
I guess that the Sketch runs its .solve() routine, which generates this error.
I don't know if it's possible to freeze it also. :|
CharlesM
Post by CharlesM »
Hello everyone,
Sorry to revive this old thread, but I think it might still be relevant as I am facing the exact same problem as fourchette. I am working with hollow bodies and i am getting
when my python script modifies the sketch. I can build the geometry "by hand" without having this issue. My guess is that since "setDatum" call solve each time a constraint is modified , it causes reconstruction problems.
I tried to simplify as much as possible my sketch, changed the order of application of each of my setDatum but it didn't solve the problem( I can't share my model due to privacy issue, but I will try to build a minimal working example ) .
Since this thread was posted, is there a way to postpone the solver until every constraint have been modified ?
CharlesM wrote: Tue Feb 07, 2023 10:52 am ...
Probably this is the right way.
Part Design and Sketcher are "meant to be scripted" on some extend, not in every of their aspects.
They are written in C++ and if developer has not made some "Python Wrapper" you have some problems to access things from Python, and from what I know stopping the Solver is not possible.
Many thinks however are doable, some of them I have done even if they are not apparently feasible, see as example:
https://github.com/onekk/freecad-doc/bl ... tut-cv1.py
For some "free hints" on how some things could be done.
I hope this may help you to some extent.
