Please always post you About info when reporting/testing/confirming bugs so we know your specs. Thanks!
Automate Reinforcement GSoC proposal
Re: Automate Reinforcement GSoC proposal
Version: 0.19.23578 (Git)
Hash: 50c3cbf00579dc4941ca743c25720d016b0453ce
Python version: 3.8.6
Locale: Spanish/Peru (es_PE)
JFYI, that is not the most up to date revision of v0.19
I already updated :
this appears in the start, but FreeCAD still runs without problems:
Version: 0.19.23756 (Git)
Hash: 9c6e9184930a52b165a0b7274e3a45d1006bfe67
00:11:18 A3 available
00:11:20 During initialization the error "No module named 'nine'" occurred in C:\Users\JTM_PC\AppData\Roaming\FreeCAD\Mod\NodeEditor\InitGui.py
00:11:20 Please look into the log file for further information
00:11:27 During initialization the error "inconsistent use of tabs and spaces in indentation (ListSelect.py, line 145)" occurred in C:\Users\JTM_PC\AppData\Roaming\FreeCAD\Mod\SelectionTools\InitGui.py
00:11:27 Please look into the log file for further information
00:11:27 scipy not found:During initialization the error "No module named 'scipy'" occurred in freecad.PyrateWorkbench
00:11:27 --------------------------------------------------------------------------------
00:11:27 Traceback (most recent call last):
File "C:\Users\JTM_PC\AppData\Roaming\FreeCAD\Mod\pyrate\freecad\PyrateWorkbench\init_gui.py", line 40, in <module>
import scipy
ModuleNotFoundError: No module named 'scipy'
During handling of the above exception, another exception occurred:
File "<string>", line 156, in InitApplications
File "C:\ProgramData\chocolatey\lib\freecad\tools\FreeCAD_0.19.23756-Win-Conda_vc14.x-x86_64\bin\lib\importlib\__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 783, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "C:\Users\JTM_PC\AppData\Roaming\FreeCAD\Mod\pyrate\freecad\PyrateWorkbench\init_gui.py", line 55, in <module>
import scipy
I was testing again:
... created column rebars again and stirrups offset inside the column
- rebar-bug.FCStd
- (89.02 KiB) Downloaded 95 times
