Automate Reinforcement GSoC proposal
Contributions from the participants, questions and answers to their projects.
Discussions of proposals for upcoming events.
Suraj Dadral
Re: Automate Reinforcement GSoC proposal
Post by Suraj Dadral »
balrobs wrote: Thu Oct 22, 2020 6:18 pm However selecting a lateral face of the beam I expected the reinforcement to be laid in trasversal direction ... it happened that way except for the rebar marked in red in the below picture.
Hi @balrobs
I tried reproducing above, but surprisingly it works fine for me (as in below models). :o
May you please share the sample model with above issue and FreeCAD version info.
My FreeCAD info:
OS: Kali GNU/Linux Rolling (GNOME/gnome)
Version: 0.19.22756 (Git) AppImage
Hash: ce87f586ee36ffe8ebcdcd3947ced4ab389ae795
Python version: 3.8.6
Locale: English/India (en_IN)
Thanks,
beam1.FCStd
(333.6 KiB) Downloaded 102 times
beam2.FCStd
(427.96 KiB) Downloaded 101 times
beam3.FCStd
(385.38 KiB) Downloaded 97 times
dwire_beam1.FCStd
(324.73 KiB) Downloaded 126 times
balrobs
Post by balrobs »
Suraj Dadral wrote: Sat Oct 24, 2020 8:29 am I tried reproducing above, but surprisingly it works fine for me (as in below models). :o
Hi @Suraj,
Sorry for not posting my system info :mrgreen:
I encountered the issue on my windows system. I'm not able to reproduce the issue on my Ubuntu system, so I will give it another try at Monday when I will be back on my windows machine.
Cheers!
OS: Ubuntu 20.04.1 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Branch: unknown
Hash: 1062b6ee0f90ae197bc816aebf4dcf1b1646aa30
Python version: 3.8.5
Qt version: 5.12.8
balrobs
Post by balrobs »
Hi @Suraj,
Back to my window machine I tried all steps done last week to reproduce the issue ... without success. It works as it should and unfortunately I didn't save the culprit file. Maybe i created and deleted the reinforcement several times and forgot to delete underlying sketches.
Sorry for wasting your time :|
Cheers
Suraj Dadral
balrobs wrote: Mon Oct 26, 2020 11:10 am Back to my window machine I tried all steps done last week to reproduce the issue ... without success. It works as it should and unfortunately I didn't save the culprit file. Maybe i created and deleted the reinforcement several times and forgot to delete underlying sketches.
Thanks @balrobs for testing and confirmation about the same. Happy to see Beam Reinforcement is working fine. :D
Suraj Dadral
jtm2020hyo wrote: Fri Oct 23, 2020 11:55 am I am interested in this feature, any date for release it with the dev version?
Hi @jtm2020hyo
Is it about the same issue reparted by balrobs. Or may you please mention in which feature you are interested. :)
Thanks,
jtm2020hyo
Post by jtm2020hyo »
Well, for Christmas I wish :
Similar features to Robot Structural Analysis, automatic RC Design, 3D grid, create animations, automatic footing design, add soil type to the variables, IFC import export, support for Pipe interference, add Risk Management Classes, a guide for pre design Columns and Beams, support for tower creation for lightning rod, add standard per country, manage the materials to connect the electrical grounding rod and mesh... All this for start.
jtm2020hyo
Excuse me, could create a option to use just lines, wires, polylines instead sketcher wb? This to create a workflow with external software exporting those lines
Suraj Dadral
jtm2020hyo wrote: Tue Jan 26, 2021 8:19 pm Excuse me, could create a option to use just lines, wires, polylines instead sketcher wb? This to create a workflow with external software exporting those lines
Hi jtm2020hyo,
Do you mean same as in the thread: https://forum.freecadweb.org/viewtopic. ... 6&p=471386
P.S. Replied there.
Thanks,
jtm2020hyo
thanks for the script, but I still think than is need an option to use all base container as Wires (3D polylines) and not Sketcher + 3D Lines + 3D arcs at the same time.
jtm2020hyo
not sure but I think I found a possible bug, in the image I tried to create a reinforcement rebar column with 1-meter offset but was create inside the column when should be in the exterior, when I tried to change the column height, then the rebar changed their height to outside in the above part, but not below.
shape to wire .FCStd
(243.6 KiB) Downloaded 95 times
anyway is a nice tool.
