Assembly 4 workbench
Re: Assembly 4 workbench
Hello, I just released a new incremental version 0.12.6 with small fixes, nothing spectacular but all over the place. Please update, test and report if you have problems
changed the ASM4-version from 0.12.5 to 0.12.6 in my FC-setup without problems handling assemblies built with 0.12.5
I don't use BOM or PartInfo - for this reason no experience with this section of ASM4
But in version 0.12.6 there is a new warning at initialization
Some older warnings on Observer-start are still there
Besides this warnings ASM4 0.12.6 and your measurement tool are working well.
Thank you for your marvellous assembly-tool
Version: 0.21.0.31917 (Git)
Hash: 4639283b459f9ff9093e289908cc003db8745b82
Python 3.10.9, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: German/Austria (de_AT)
* AddonManager
* Assembly4 0.12.6
* Draft
* Fem
* Idf
* Image
* Import
* Mesh
* MeshPart
* Part
* PartDesign
* SetMyStyle
* Show
* Sketcher
* Spreadsheet
* Start
* TechDraw
* Tux
* Web
My workflow: create single components in PartDesign and arrange them with Zolko's Assembly4
(https://github.com/Zolko-123/FreeCAD_Assembly4 )
FreeCAD works pretty well and stable for me !!
Hymn of Praise valid again since FreeCAD 0.22.35449
yes, this is new and in order
I don't see these, when does it happen ?Some older warnings on Observer-start are still there
thank-you for your kind wordsBesides this warnings ASM4 0.12.6 and your measurement tool are working well.
This warning is reported whenever I start the measurement-tool. The Measure-form opens in the Combo-View 'Tasks'-panel and simultaneously is this warning in Report View.I don't see these, when does it happen ?Some older warnings on Observer-start are still there
I assume there is an issue with window-handling in new builds - there is Qt 5.15.6 now and I recognized similar strange behaviour with QtWebEngine before
viewtopic.php?f=3&t=75439.
The QtWebEngine-warning can be silenced by not activating Start-Workbench.
Still remaining are warnings when ASM4-Measurement is activated and whenever one or more panels of ComboView-combined window (means following configuration) are placed adjacent to ComboView-window or relocated out of ComboView -> Here 'ReportView' separated (first warning) and repositioned three times (next three warnings)
Similar is the situation with the Measure-Panel -> new panel leads to warning about layout issues.
And the big Q is leading letter -> QLayout or QMainWindowLayout.
Don't know what it is, but it seems to be a (window??) layout thing
At least I can't see any influence on functionality of FreeCAD or ASM4 - everything is working well.
Ah so it's a ComboView thing ... I use separated Task, Tree and Property views. The ComboView must have some additional QLayout thingy somewhere around. I'll try to give it a try.
In the meanwhile, in order to check that this is indeed the problem, could you please test your same setup by separating the ComboView:
Edit > Preferences > General > Tree View Mode > Tree View and Property View
Changed the setting to 'Tree View and Property' and split up the Combo View in six standalone panel-windows.Zolko wrote: ↑Fri Mar 03, 2023 8:34 am
As long as this panels are standalone each of them can be dragged, resized and joined with another window without any warnings !!!
Dragging one panel out of a joined configuration causes this QMainWindowLayout-warning again. Each movement of this panel is an additional warning in 'Report View', the 'hosting' window can be moved without warnings.
An example: 'Pyhton console' and 'Property view' are combined in one common window, dragging out e.g. 'Phyton consol' causes a warning, moving this (now standalone) panel -> next warning and so on, dragging 'Property view' - now a standalone panel also - no warning in 'report view'
Maybe this 'out-of-bounds value' is related to the window-boundaries of the former 'home' of the dragged-out panel.
When I ended with the panel layout shown above, closed FC and started again for a 'new session' I got this error in 'Report view' and 'Tree view' panel is messed up.
Hopefully this tests will help you.
By the way:
splitting up the panels showed that the 'Combo View' is at least the 'Tasks' panel - I found this naming a bit confusing.
I've understood ComboView as the combination of TreeView and PropertyView with Tasks-panel on 'second page'
Changing the preferences away from ComboView it is odd-looking when ComboView-window is still there.
Not a big issue for me - I join Property-, Tree- and Tasks-panel back to ComboView. For me the maximum useful configuration
so this is not caused by the Asm4 Measurement tool ?rmn_hr wrote: ↑Fri Mar 03, 2023 6:16 pm Changed the setting to 'Tree View and Property' and split up the Combo View in six standalone panel-windows.
Your ASM4 measurement tool creates a different warning - my guess: using the 'Tasks'-panel for selecting the measurement mode and displaying results requests some window-actions within the 'Tasks'-panel and Qt is missing something.
I guess that anything has changed in Qt since Qt 5.15.4 (Qt version in weekly build 31513) or maybe in Python 3.10 (changed from Py 3.10.8 to Py 3.10.9) or in interaction - I have no idea.
The reasons for this warnings are not originated in ASM4-measurement-tool -> I'm very sure about this.
Only warning about 'Pylib anytree missing' and 'exportFiles not available' are ASM4 v0.12.6-related.
I used ASM4 v0.12.5 in several builds even before 31513 - never any warnings.
Then came Qt 5.15.6 (weekly build 31625 - here I observed it first)) and warnings regarding layout of ComboView panels (including the ASM4 measurement form) and this QtWebEngine-issue with the 'Start' workbench were there.
It must be a Qt-theme
Thankfully only layout warnings - no influence on FreeCAD-performance
Hello Zolko,
Many thanks for your efforts. I'm trying to figure out if I can switch from SW to FC and therefore I want to see the power of A4 WB.
I use
OS: Ubuntu 22.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.2.29603 (Git) AppImage
* Assembly4 0.12.6
* Curves 0.6.8
* frame 0.1.0
* Help 1.0.3
* Silk 1.0.0
* PieMenu 1.2.6
* Manipulator 1.5.0
* lattice2 1.0.0
When I try to make a BOM, I have the messages:
ASM4 WARNING: Pylib anytree is missing, exportFiles is not available
Some file is missing - please see the attached photo.
At work I installed also the FC 0.20.2 on Windows 10 and I have the same issue.
Kind regards
Gabriel
I use
* Assembly4 0.12.6
* Curves 0.6.8
* frame 0.1.0
* Help 1.0.3
* Silk 1.0.0
* PieMenu 1.2.6
* Manipulator 1.5.0
* lattice2 1.0.0
Kind regards
Gabriel
- Assembly $ BOM error.jpg (100.22 KiB) Viewed 2495 times
