yes, BOM is not working very well yet
Assembly 4 workbench
Re: Assembly 4 workbench
Just install anytree. It will work.
Hello Zolko,
Thanks for your quick reply.
I'm pleasantly surprised by your honesty.
Hello leoheck,
Thanks for the tip. I*ll install the anytree.
Kind regards
Gabriel
Hello leoheck,
Kind regards
Gabriel
Dear Zolko,
The measure-tool in the assembly-4-wb is one of my favorite tools. I usually use it with 'show components' enabled to document distances in my models. Today I wanted to document an area of an face but the area is only written into the Results-field but not shown as 'component' in the 3d-Model.
Is it easily possible to add the area and e.g. volume to the components exported into the 3D model?
BR
HoWil
BR
HoWil
yeah, it should not be too difficult. But it's also not very high on the priority list. May I suggest you open an Issue on the WB's GitHub page (see my signature) and describe precisely what you'd like to see ?
I'm trying to figure out how to name parts etc. to get some more structure to the "Insert a Part" dialog box. If you look at the last two in the available parts you might see what I mean. Where do the text "_1_mm_M3_nut_A" come from?
- freecad-ass4-insert.png (14.13 KiB) Viewed 2781 times
Hi and welcome to the forum!
I'm not familiar with Assembly4, but you should consider to add a preferably very simple file showing the issue.
I might have found the problem or a bug. The odd names comes from files starting with a nummer in the file name. The assembly is not a problem, just how it is viewed in the dialog box.
You are right about that. I had seen that a while back myself that if you name something with a number as the first character, Assembly 4 does not like that for some reason. I've just made it a point not to start with numbers
I've attached a sample file that shows the issue. Notice that when you try to insert the part the list gets messed up.
I've added this to the bug list. #418
- Naming_Insert_Issue.FCStd
- (35.88 KiB) Downloaded 25 times
