FreeCAD Trails Workbench (Transportation and Geomatics)
Re: FreeCAD Trails Workbench (Transportation and Geomatics)
I am having trouble installing the workbench by running "git clone --recursive https://github.com/joelgraff/freecad.trails.git". I get the following error:
Fetched in submodule path 'pivy_trackers', but it did not contain ab0ec4f2cf99bbfef79ca4800ca527ea4cfb2d8c. Direct fetching of that commit failed.
How do I fix this?
How do I fix this?
- HakanSeven12
You can install it from addon manager
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
I am trying to import survey points, using the Trails WB,
but keep getting this error.
Would somebody perhaps know what causes this error
and what I can do to make it work.
12:56:27 Traceback (most recent call last):
File "/home/admin/.FreeCAD/Mod/Trails/Trails/objects/georigin.py", line 60, in onChanged
node = self.get_geoorigin()
File "/home/admin/.FreeCAD/Mod/Trails/Trails/objects/georigin.py", line 102, in get_geoorigin
if not isinstance(node, coin.SoGeoOrigin):
<class 'AttributeError'>: module 'pivy.coin' has no attribute 'SoGeoOrigin'
File "/home/admin/.FreeCAD/Mod/Trails/Trails/viewproviders/view_cluster.py", line 79, in attach
self.geo_coords = coin.SoGeoCoordinate()
<class 'AttributeError'>: module 'pivy.coin' has no attribute 'SoGeoCoordinate'
File "/home/admin/.FreeCAD/Mod/Trails/Trails/viewproviders/view_cluster.py", line 120, in onChanged
self.point_labels.removeAllChildren()
<class 'AttributeError'>: 'ViewProviderCluster' object has no attribute 'point_labels'
File "/home/admin/.FreeCAD/Mod/Trails/Trails/viewproviders/view_cluster.py", line 180, in updateData
self.markers.markerIndex = marker_dict[marker]
<class 'AttributeError'>: 'ViewProviderCluster' object has no attribute 'markers'
- HakanSeven12
Try appimage version of freecad. This will fix the issue.
thank you. the appimage doesn't seem to have this bug,HakanSeven12 wrote: ↑Wed Mar 09, 2022 2:31 pm Try appimage version of freecad. This will fix the issue.
and I could import survey points, but the FreeCAD AppImage
runs very unstable on Leap 15.2
so, it's not a solution for me and I am back to Civil 3D to process land survey.
I really miss the old Geomatics WB, where I could import
maps from OSM and do a lot more than in Trails.
- HakanSeven12
Python 3.10 causes this issue. It breaks pivy. I have ideas about making a seperate gis module for osm and other geomatics stuffs. But I lost my interes on freecad. Maybe I can do something in the feature. We will see.
- HakanSeven12
I worked on this one a little bit and I created another workbench for gis releated tools.freeCAD-beginner wrote: ↑Fri Mar 11, 2022 12:08 pm I really miss the old Geomatics WB, where I could import
https://twitter.com/Seven12Hakan/status ... 806Sg&s=19
Hello guys, I've got a question concerning the trails tutorial, would anyone be able to assist here?
- Snipaste_2022-06-04_22-33-19.png (13.91 KiB) Viewed 2215 times
I have also wondered about this for a while but has no time to find out, good to have some pointers
how to delete some terrain triangle?
