Select the terrain. Click to the "delete triangle" option. Select the faces that you want to remove then press to R button on keyboard.
FreeCAD Trails Workbench (Transportation and Geomatics)
- HakanSeven12
Re: FreeCAD Trails Workbench (Transportation and Geomatics)
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
I'm trying to delete these triangles, but can't do.
https://download.gg/fr/file-14022678_9fc022ade3959259
- Capture.JPG (20.97 KiB) Viewed 1901 times
- HakanSeven12
I tried too. Its looks like something broken with pivy.
This code code was working at 0.19 but its broken now.
For a workaround you can set the max length to 5 to remove these triangles.
22:55:11 < class ' SystemError " >
22:55:11 Traceback ( most recent call last ) :
22:55:11 File " /home/hakanseven/var/app/org.freecadweb.FreeCAD/data/FreeCAD/Mod/Trails/./Trails/guitools/gui_terrain_editor.py " , line 227 , in delete
22:55:11 face_detail = coin.cast (
22:55:11 SystemError : < built - in function cast > returned NULL without setting an error
- HakanSeven12
The bug fixed with new pivy 0.6.8 release.
https://github.com/coin3d/pivy/pull/99
https://github.com/coin3d/pivy/releases/tag/0.6.8
I'm fairly new to FreeCAD or any other CAD program. I successfully imported my points with Trails and the surface creation was also successful, contour lines are also visible.
What I'm trying to achieve is:
- showing the surface/terrain with contour lines on a TechDraw view, with elevation data if possible
- using the surface as a terrain for Arch Site and to be able to do volume addition/subtractions.
I tried inserting a view on the TechDraw WB with Insert View, but nothing the surface does not show up, only my test box solid.
With Arch Site, I added the surface to the Site as terrain but the volume addition/subtraction buttons are disabled. I don't know if it's because the surface is not suitable for Site or for some other reason.
Do you have any suggestions?
To add to an Arch_Site:
- Double-click the Site object.
- Select the object you want to add.
- Select the "Additions" folder in the task panel.
- Press the "+ Add" button (which should now be enabled).
Thanks for the tip! I could now add the box to the site, but it seems to me the subtraction itself does nothing. Maybe the surface has to be converted to something else?
I do not know the Trails Workbench. Can you post your file?
Hi, sure.
I'm using FreeCAD 0.20.2 appimage with the Trails release available on Github: https://github.com/joelgraff/freecad.tr ... 02.07.2021
- szirt-terrain.FCStd
- (30.21 KiB) Downloaded 40 times
The Terrain object must have a Shape, the Surface object in the file does not have that. You can convert it with the code below.
import Part
doc = App.ActiveDocument
obj = doc.getObject("Surface")
new = doc.addObject("Part::Feature", "SurfaceShape")
shape = Part.Shape()
shape.makeShapeFromMesh(obj.Mesh.Topology, 0.1)
new.Shape = shape
doc.recompute()
