That's nice I will take a lookJavierBrana wrote: ↑Sat Oct 09, 2021 7:58 pm If you want to soften the contours then check and use my code. I have implemented it already. In future I want to close them and put labels.
FreeCAD Trails Workbench (Transportation and Geomatics)
- HakanSeven12
Re: FreeCAD Trails Workbench (Transportation and Geomatics)
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
- HakanSeven12
I made a new restructure for workbench. It's not include GIS tools for now. Maybe we need a seperate workbench for it. If you need these tools use standard Trails. To install it you need to extract folder to your . FreeCAD/Mod directory.
https://github.com/HakanSeven12/Trails
https://www.patreon.com/posts/57429377
- HakanSeven12
Joel made a representation in FOSS4G for Trails. Take a look:
Trying to find more explanation how to use the Swept Path Analysis - a really long awaited feature - can't find in the github readme, any idea ?
- HakanSeven12
Its not part of trails for now and I don't know what is the status of this tool. Maybe Joel can answer this question
- eccioloste
Step by step Trails is improving a lot!
Congrats!
Congrats!
- HakanSeven12
Thanks.
I renamed surface to terrain and points to clusters. Also started to add task panels. Firstly I added some data addition methods under Terrain->"Add Data". You can select clusters from a panel now.
https://www.patreon.com/posts/58537311
- cluster selector.PNG (7.96 KiB) Viewed 3859 times
- HakanSeven12
- export clusters.PNG (15.61 KiB) Viewed 3781 times
- HakanSeven12
- import point.PNG (19.18 KiB) Viewed 3532 times
