Scripting Path workbench
tcs_ulrich
Post by tcs_ulrich »
I want to generate G-code from an in Script created Object (an Plate with Text as Pocket).
But i find no Documentation how to generate the "Path Operation" and the "Profile based on Faces"
best regards
Christian
tcs_ulrich
Re: Scripting Path workbench
Hi, in meantime ive get an patially working Solution in this German Thread: https://forum.freecadweb.org/viewtopic. ... 45#p378645
But i have at time no working Solution to Create an Tool definition and Assign Tools to Path Operations, has anyone an clue how that can be done in an python script ?
etrombly
Post by etrombly »
This is how I create a PathCustom and assign it to a job and toolcontroller. You should be able to modify it to do what you need.
obj = FreeCAD.ActiveDocument.addObject("Path::FeaturePython", "Custom")
    PathScripts.PathCustom.ObjectCustom(obj)
    obj.ViewObject.Proxy = 0
    obj.Gcode = gcode
    PathScripts.PathUtils.addToJob(obj)
    obj.ToolController = PathScripts.PathUtils.findToolController(obj)
edit: This just assigns the first active tool. Not sure about creating a new one.
tcs_ulrich
Ive found an solution i can Create an TC with
drill1mm = Path.Tool("1mm Endmill",tooltype="EndMill",diameter=1)
tc1mm = PathToolController.Create('drill1mm', tool=drill1mm)
And Assign with
FontCut.ToolController = tc1mm
alanchackomathew
Post by alanchackomathew »
etrombly wrote: Fri Mar 20, 2020 4:13 pm This is how I create a PathCustom and assign it to a job and toolcontroller. You should be able to modify it to do what you need.
    obj.Gcode = gcode
How you created a job using python.
alanchackomathew
    obj.Gcode = gcode
Hi, how you created the job using python command. Could you help me please?. Its dor my project. I have to automate the path process.
etrombly
Post by etrombly »
I haven't created a job with python before. It would be something along the lines of:
from PathScripts import PathJob
job = PathJob.create("job_name", "model_object")
That was giving me an error, but is pretty close to what you would need to do. Maybe someone else that has tried it before can help more.
wildzero
Post by wildzero »
Any update on this issue? Have exactly the same problem creating a path job via python
wildzero wrote: Sat Apr 15, 2023 12:12 am Any update on this issue? Have exactly the same problem creating a path job via python
Please describe in detail what you have tried, and where it fails and what is the result.
wildzero
Post by wildzero »
Thank you for the query. I have no problems after realizing how a path job is basically created
import PathScripts.PathJob as PathJob
PathJob.Create(name, base)
Without documentation it was just a bit fiddly to find the commands. I'm digging through the src/Mod/Path/PathTests folder to gather the appropriate information.
Some more end user documentation on the subject would be appreciated. But so far I'm getting by.
