I create a simple box in freecad. The .inp of this file is the following one:
DEFAULT .INP file
** written by FreeCAD inp file writer for CalculiX,Abaqus meshes
** highest dimension mesh elements only.
** Nodes
*Node, NSET=Nall
1, 0, 0, 10
2, 0, 0, 0
3, 0, 30, 10
4, 0, 30, 0
5, 20, 0, 10
6, 20, 0, 0
7, 20, 30, 10
8, 20, 30, 0
9, 0, 0, 5
10, 0, 15, 10
11, 0, 30, 5
12, 0, 15, 0
13, 20, 0, 5
14, 20, 15, 10
15, 20, 30, 5
16, 20, 15, 0
17, 10, 0, 0
18, 10, 0, 10
19, 10, 30, 0
20, 10, 30, 10
21, 0, 15, 5
22, 0, 7.5, 2.5
23, 0, 7.5, 7.5
24, 0, 22.5, 7.5
25, 0, 22.5, 2.5
26, 20, 15, 5
27, 20, 7.5, 2.5
28, 20, 7.5, 7.5
29, 20, 22.5, 7.5
30, 20, 22.5, 2.5
31, 10, 0, 5
32, 5, 0, 2.5
33, 5, 0, 7.5
34, 15, 0, 7.5
35, 15, 0, 2.5
36, 10, 30, 5
37, 5, 30, 7.5
38, 5, 30, 2.5
39, 15, 30, 7.5
40, 15, 30, 2.5
41, 10, 15, 0
42, 5, 22.5, 0
43, 5, 7.5, 0
44, 15, 7.5, 0
45, 15, 22.5, 0
46, 10, 15, 10
47, 5, 22.5, 10
48, 5, 7.5, 10
49, 15, 7.5, 10
50, 15, 22.5, 10
51, 10, 7.5, 7.5
52, 10, 7.5, 2.5
53, 10, 22.5, 7.5
54, 10, 22.5, 2.5
55, 5, 15, 7.5
56, 5, 15, 2.5
57, 10, 15, 5
58, 5, 7.5, 5
59, 15, 15, 2.5
60, 15, 15, 7.5
61, 15, 7.5, 5
62, 5, 22.5, 5
63, 15, 22.5, 5
** Volume elements
*Element, TYPE=C3D10, ELSET=Evolumes
37, 46, 5, 1, 31, 49, 18, 48, 51, 34, 33
38, 6, 41, 2, 31, 44, 43, 17, 35, 52, 32
39, 46, 3, 7, 36, 47, 20, 50, 53, 37, 39
40, 41, 8, 4, 36, 45, 19, 42, 54, 40, 38
41, 41, 46, 21, 31, 57, 55, 56, 52, 51, 58
42, 26, 46, 41, 31, 60, 57, 59, 61, 51, 52
43, 41, 21, 46, 36, 56, 55, 57, 54, 62, 53
44, 26, 41, 46, 36, 59, 57, 60, 63, 54, 53
45, 46, 1, 21, 31, 48, 23, 55, 51, 33, 58
46, 6, 26, 41, 31, 27, 59, 44, 35, 61, 52
47, 41, 4, 21, 36, 42, 25, 56, 54, 38, 62
48, 26, 8, 41, 36, 30, 45, 59, 63, 40, 54
49, 26, 5, 46, 31, 28, 49, 60, 61, 34, 51
50, 41, 21, 2, 31, 56, 22, 43, 52, 58, 32
51, 26, 46, 7, 36, 60, 50, 29, 63, 53, 39
52, 46, 21, 3, 36, 55, 24, 47, 53, 62, 37
53, 3, 21, 4, 36, 24, 25, 11, 37, 62, 38
54, 6, 5, 26, 31, 13, 28, 27, 35, 34, 61
55, 1, 2, 21, 31, 9, 22, 23, 33, 32, 58
56, 26, 7, 8, 36, 29, 15, 30, 63, 39, 40
57, 3, 1, 21, 46, 10, 23, 24, 47, 48, 55
58, 46, 7, 5, 26, 50, 14, 49, 60, 29, 28
59, 26, 41, 8, 6, 59, 45, 30, 27, 44, 16
60, 21, 2, 4, 41, 22, 12, 25, 56, 43, 42
** Define element set Eall
*ELSET, ELSET=Eall
Evolumes
** Element sets for materials and FEM element type (solid, shell, beam, fluid)
** written by write_element_sets_material_and_femelement_type function
*ELSET,ELSET=SolidMaterialSolid
Evolumes
** Node sets for fixed constraint
** written by write_node_sets_constraints_fixed function
** FemConstraintFixed
*NSET,NSET=FemConstraintFixed
1,
2,
5,
6,
9,
13,
17,
18,
31,
32,
33,
34,
35,
** Materials
** written by write_materials function
** Young's modulus unit is MPa = N/mm2
** Density's unit is t/mm^3
** FreeCAD material name: CalculiX-Steel
** Steel
*MATERIAL, NAME=SolidMaterial
*ELASTIC
210000, 0.300
*DENSITY
7.900e-09
** Sections
** written by write_femelementsets function
*SOLID SECTION, ELSET=SolidMaterialSolid, MATERIAL=SolidMaterial
** At least one step is needed to run an CalculiX analysis of FreeCAD
** written by write_step_begin function
*STEP
*FREQUENCY
3,0.0,100000.0
** Fixed Constraints
** written by write_constraints_fixed function
*BOUNDARY
FemConstraintFixed,1
FemConstraintFixed,2
FemConstraintFixed,3
** Outputs --> frd file
** written by write_outputs_types function
*NODE FILE
U
*EL FILE
S, E
** outputs --> dat file
*NODE PRINT , NSET=Nall
U
*EL PRINT , ELSET=Eall
S
** written by write_step_end function
*END STEP
** CalculiX Input file
** written by write_footer function
** written by --> FreeCAD 0.17.13528 (Git)
** written on --> Sun Sep 23 12:50:46 2018
** file name --> SimpleBox.FCStd
** analysis name --> Analysis
** Units
** Geometry (mesh data) --> mm
** Materials (Young's modulus) --> N/mm2 = MPa
** Loads (nodal loads) --> N
MY .INP file
** Nodes
*Node, NSET=Nall
1, 0, 0, 10
2, 0, 0, 0
3, 0, 30, 10
4, 0, 30, 0
5, 20, 0, 10
6, 20, 0, 0
7, 20, 30, 10
8, 20, 30, 0
9, 0, 0, 5
10, 0, 15, 10
11, 0, 30, 5
12, 0, 15, 0
13, 20, 0, 5
14, 20, 15, 10
15, 20, 30, 5
16, 20, 15, 0
17, 10, 0, 0
18, 10, 0, 10
19, 10, 30, 0
20, 10, 30, 10
21, 0, 15, 5
22, 0, 7.5, 2.5
23, 0, 7.5, 7.5
24, 0, 22.5, 7.5
25, 0, 22.5, 2.5
26, 20, 15, 5
27, 20, 7.5, 2.5
28, 20, 7.5, 7.5
29, 20, 22.5, 7.5
30, 20, 22.5, 2.5
31, 10, 0, 5
32, 5, 0, 2.5
33, 5, 0, 7.5
34, 15, 0, 7.5
35, 15, 0, 2.5
36, 10, 30, 5
37, 5, 30, 7.5
38, 5, 30, 2.5
39, 15, 30, 7.5
40, 15, 30, 2.5
41, 10, 15, 0
42, 5, 22.5, 0
43, 5, 7.5, 0
44, 15, 7.5, 0
45, 15, 22.5, 0
46, 10, 15, 10
47, 5, 22.5, 10
48, 5, 7.5, 10
49, 15, 7.5, 10
50, 15, 22.5, 10
51, 10, 7.5, 7.5
52, 10, 7.5, 2.5
53, 10, 22.5, 7.5
54, 10, 22.5, 2.5
55, 5, 15, 7.5
56, 5, 15, 2.5
57, 10, 15, 5
58, 5, 7.5, 5
59, 15, 15, 2.5
60, 15, 15, 7.5
61, 15, 7.5, 5
62, 5, 22.5, 5
63, 15, 22.5, 5
** Volume elements
*ELSET, ELSET=Eall
Evolumes
37,
39,
40,
41,
42,
43,
44,
45,
47,
48,
49,
50,
51,
52,
53,
55,
56,
57,
58,
60,
*ELSET,ELSET=MaterialSelectedNodes
38,
46,
54,
59,
1,
2,
5,
6,
9,
13,
17,
18,
31,
32,
33,
34,
35,
** Materials
** Steel
*ELASTIC
210000, 0.300
*DENSITY
7.900e-09
*MATERIAL, NAME=SolidMaterialSelectedNodes
*ELASTIC
210000, 0.300
*DENSITY
7.900e-09
** Sections
*SOLID SECTION, ELSET=MaterialSelectedNodes, MATERIAL=SolidMaterialSelectedNodes
*STEP
*FREQUENCY
3,0.0,100000.0
*BOUNDARY
*NODE FILE
U
*EL FILE
S, E
U
S
*END STEP
** Units
The main problem is how to execute calculix from FreeCAD python API in order to read my.inp file and simulate.
I attached my file: SimpleBox.FCStd
BTW: This post is related with the following three questions:
https://forum.freecadweb.org/viewtopic.php?f=18&t=31100
https://forum.freecadweb.org/viewtopic.php?f=18&t=31123
https://forum.freecadweb.org/viewtopic.php?f=22&t=23467 - here I post here too but I dont if it is the correct place, because it is related with FEM and run calculix solver....
Thank you in advance,
Ekaitz.
EDIT: Solved here:
https://forum.freecadweb.org/viewtopic. ... 10#p258417
Thank you bernd.
