[Solved] Arch Space Label not displayed right with Py3 Build
furti
Post by furti »
With Py3 the label of a Arch Space is not displayed correctly.
ArchSpaceLabel.FCStd
(15.45 KiB) Downloaded 29 times
OS: Windows 10
Version: 0.18.14575 (Git)
Hash: a624fee2c27bbbb869df6a8ce40438953a282a8c
Python version: 3.6.6
Qt version: 5.6.2
Locale: German/Austria (de_AT)
looo
Re: Arch Space Label not displayed right with Py3 Build
Post by looo »
I guess it's best to wait for yorik joining the py3-side of FreeCAD, as he knows best how things in Arch and Draft should behave. In the meantime you can maybe create a bugreport for these unicode problems.
furti
Post by furti »
Created issue in bug tracker for this https://www.freecadweb.org/tracker/view.php?id=3590
furti
Post by furti »
looo wrote: Tue Sep 11, 2018 1:32 pm ping
Thougth this should be fixed?
But still seems to not work properly
Tested with:
OS: Windows 10
Version: 0.18.14993 (Git)
Hash: 1e6818b6fbf86ad08d8fc85252dddcae8891dd54
Qt version: 5.6.2
looo
Post by looo »
This was solved in an updated version of pivy. I guess your updated FreeCAD does not include the updated pivy.
Can you post the output of:
import pivy
pivy.__version__
Maybe @sgrogan can update the build to use pivy 0.6.5a0. Also maybe someone (@triplus?) familiar with the version-stuff shown in the about-dialog can update this widget to also show the pivy version. The version of pivy wasn't always available this way so using something like this:
try:
	import pivy
except ImportError:
	# no pivy installed
	pivy_version = None
else:
	try:
		pivy_version = pivy.__version__
	except AttributeError:
		pivy_version = "<=0.5.0"  # assume this is the oldest available
triplus wrote:
sgrogan wrote:
sgrogan
Post by sgrogan »
looo wrote: Tue Oct 23, 2018 1:42 pm Maybe @sgrogan can update the build to use pivy 0.6.5a0
Will do.
"fight the good fight"
triplus
Post by triplus »
looo wrote: Tue Oct 23, 2018 1:42 pm Also maybe someone (@triplus?) familiar with the version-stuff shown in the about-dialog can update this widget to also show the pivy version.
I tend to avoid C++ as much as i can. Therefore Werner likely is your best bet. In addition i am not the biggest fan of lengthy FreeCAD info. In 99% of the cases such specific info is more or less spam. And in that 1% (where it could prove to be useful) you need an expert anyway. To make some sense of it. Like seen and demonstrated in this thread. And an expert usually knows on what to ask for. To get the needed info and to confirm the assumption.
sgrogan
Post by sgrogan »
furti wrote: Sat Oct 20, 2018 2:17 pm Thougth this should be fixed?
pivy is updated. Can you try again?
furti
Post by furti »
sgrogan wrote: Thu Oct 25, 2018 8:56 pm Can you try again?
Tested again and still not working. Am I doing something wrong?
Version used is
OS: Windows 10
Version: 0.18.15115 (Git)
Hash: 684b4ab03a27231e0cc603ca815bf9ea367fd0b9
Qt version: 5.6.2
looo wrote: Tue Oct 23, 2018 1:42 pm import pivy
pivy.__version__
My FreeCAD Versions pivy has no "__version__" field? But it has a "pivy.sys.version". Maybe this helps:
'3.6.6 | packaged by conda-forge | (default, Jul 26 2018, 11:48:23) [MSC v.1900 64 bit (AMD64)]'
looo
Post by looo »
I guess this means the pivy version is 0.6.4b1 as this is the only build available from conda-forge without the __version__. So maybe something went wrong during updating the pivy-package. Maybe @sgrogan can have another look. Pivy 0.6.5a0 has the fix included.
