LibLathe - Lathe Path Generation
Re: LibLathe - Lathe Path Generation
I have as suggested by @mlampert added the parentjob to each of the libLathe turning Op's.It is the last function in each file. I commented out the original function and added the changed code below. The files are attached so others can test.
These files should work as intended with the origional PathOPGiu.py. Reading the code there is still a few things to implement but the operations are very usable for creating paths. Most of the code is way over my head though.
- PathTurnPartoff.py
- (3.84 KiB) Downloaded 111 times
- PathTurnFace.py
- (4.22 KiB) Downloaded 92 times
- PathTurnRough.py
- (3.93 KiB) Downloaded 98 times
- PathTurnProfile.py
- (3.96 KiB) Downloaded 103 times
I am having issue with liblathe outputting the Y coordinate in the gcode file. Thanks the help
I attached a test file
OS: Windows 10 Version 1809
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
* A2plus 0.4.56a
* Assembly4 0.12.0
* Curves 0.4.4
* fasteners 0.3.45
* FeedsAndSpeeds 0.4.0
* FreeCAD_Turning_Addon-master 0.1.0
* Manipulator 1.4.9
* sheetmetal 0.2.49
* ThreadProfile 1.81.0
- teat1 roughing.txt
- (5.44 KiB) Downloaded 70 times
Hard to say anything without the FreeCAD file - except that you should retry with 0.21.
Your post would be easier to read if you enlose the Gcode output directly in code tags. With a file it's saving - opening an editor - loading the file - removing the file, instead of just looking at it.
Your post processor needs to not output the Y param. If you are using the post in the liblathe as a start point. The LATHE_MODE flag in your post is probably set to False. Set it to True You can set the Post Processor Args in the job to --lathe-mode.
LATHE_MODE = True
Hello guys,
was very excited in trying this addon on Freecad 0.19... but no luck!
It seems to be installed (see attached pics) but NO one link, icon, instruction was added to Path menus...
Could someone help me, please?
Gian
Gian
- Immagine 2022-12-22 144129.jpg (70.35 KiB) Viewed 2252 times
- Immagine 2022-12-22 144621.jpg (173.33 KiB) Viewed 2252 times
- Immagine 2022-12-22 144013.jpg (74.98 KiB) Viewed 2252 times
Update to v0.20.2 and test ?
well... not exactly the answer I was hoping for, but thanks for the quick reply: I'll try 0.20 as suggested!
Regards,
Gian
Regards,
Gian
Greetings FreeCAD forum members.
My first post here
I'm looking to start using the LibLathe addon in the latest version of FreeCAD.
but
I'm confused as to why it's not showing up in the Addon Manager list.
The gitHub files ... "FreeCAD_Turning_Addon-master" and "LibLathe-master" have been added to the "MOD" folder.
Can anyone guide me to what I've done wrong ?
THX much
Steve
My first post here
but
THX much
Steve
- Screenshot (1).jpg (134.55 KiB) Viewed 1823 times
Currently living my best life on the Southern Oregon Coast
60 years experience in design, fabrication.
Certified welder TIG, MIG, Stick, Oxy/Acetylene processes.
3D CAD modeling, CNC machining, 3D printing, CO2 laser cutting.
Hi and welcome to the forum!
You should always add your FreeCAD infos to such posts.
There is another Mod folder for your personal Addons. On Windows it’s in %APPDATA%\FreeCAD.
THX chrisb
Is this what you mean by FreeCAD info ? :
FreeCAD: 64-bit
As per your suggestion I searched my computer for : %APPDATA%\FreeCAD to no avail.
Is this an administrator only task ?
FreeCAD: 64-bit
