The CAD we gone use at work is not able to extract faces from solids easily. I need a lot of faces from solids for a project. My idea was as follows.
- export the building model from Allplan as ifc
- import the model in FreeCAD
- create facebinder from solids for all neded faces
... works great so far
- export the facebinder faces to ifc --> the exported ifc is empty
- import ifc in Allplan
Does ifc export support export of faces ?
cheers bernd
IFC export of facebinder objects
- facebinder.FCStd
- (10.98 KiB) Downloaded 133 times
Re: IFC export of facebinder objects
I think facebinder is like a Draft element (Dwire). They cannot be exported as ifc files, yet.bernd wrote: ↑Fri Aug 10, 2018 6:58 am The CAD we gone use at work is not able to extract faces from solids easily. I need a lot of faces from solids for a project. My idea was as follows.
cheers bernd
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
In older versions of Freecad (Freecad 0.19) it was possible to export facebinder geometry directly to ifc file. In ifc, the facebinder was correctly displayed as IfcBuildingElementProxy with face geometry. I haven't found a way to export facebinder geometry to ifc in newer versions. Maybe I'm doing something wrong. Otherwise, it would be great to restore this posibility again in newer versions. Thank you so much for the reactions.
Welcome @Jan6512
Can you file a bug report following the bug reporting guideline please ? Much better for developer to avoid missing it out.
It is not a problem of the facebinder object. Faces at all are not exported as geometrical objects. A facebinder is a face.
Examples attached ... The line objects in the ifc are just annotations and not real objects.
