Note 2 on the bottom of
https://wiki.freecad.org/Basic_TechDraw_Tutorial#Notes says:
> This drawing was produced in v0.18. It shows dimensions in the proper format for an isometric view. In v0.17 the extension lines will be perpendicular to the edge rather than aligned with the axes.
I'm using v0.20.1, and the dimension lines show up perpendicular to the edge rather than aligned with the Y axis. Is there an option I'm missing?
ETA: In Combo View I could choose the dimension and it's Data tab and then adjust Override to Angle Override: true, Line Angle: -30.00°, Extension Angle: -150.00° to force it like the image in the tutorial. Is that the right way to do it, or is there something else in v0.18+ that makes doing this more straightforward?
