An example of Gordon Surface based upon OCC
Chris_G
Post by Chris_G »
Here is an interesting thread to read about Curve Network Interpolation
In the latest comments of the thread are some links about an implementation of these Gordon Surfaces based upon OCC.
The surface workbench would definitely deserve such a feature !
freecad-heini-1
Re: An example of Gordon Surface based upon OCC
Post by freecad-heini-1 »
Thank you so much Chris, very interesting to me.
I hope that you and / or Werner could integrate this tools into the Surface workbench.
I'm impressed:
microelly2
Post by microelly2 »
interesting to see a general implementation.
I used the idea to stretch surfaces to a given area by 2 x 2 lines.
https://youtu.be/n8UqkWirIS0
I use simply u*v, u*(1-v), v*(1-u), (u-1)*(v-1) as blending functions.
this was the ide for a 3 x 3 pattern (still in 2D).
https://youtu.be/UQZCsEjYSTM
hammax
Post by hammax »
# Me Too
UR_
Post by UR_ »
I think the last sgrogan needs ATM, is another dependency :shock:
rainman110 commented on 28 May
...The code is pretty hefty and is roughly 3000 lines of code long. Hence, you need tigl for now.
Chris_G
Post by Chris_G »
UR_ wrote: Sat Jul 07, 2018 5:20 pm I think the last sgrogan needs ATM, is another dependency :shock:
I totally agree that FreeCAD shouldn't get any new big dependency.
The Gordon surface implemented in tigl "seems" to be spread in a couple of files only.
In my opinion, it would be better to make our own feature, based on their work, if licenses compatibility is OK.
... Or wait for OCC to integrate it ?
I would like to give a try at a FC+python port first, to see how it works ...
microelly2
Chris_G wrote: Sat Jul 07, 2018 5:45 pm
+1
freecad-heini-1
Chris_G wrote: Sat Jul 07, 2018 5:45 pm The Gordon surface implemented in tigl "seems" to be spread in a couple of files only.
+1
hammax
Post by hammax »
Hi Chris,
you are actually working on the GordonSurface-feature (I'm following your CurvesWB-experiments in GitHub)
and I'm curious seeing first results.
Used your example for a loft-experiment => Gordon will surely be better.
Chris_G
Post by Chris_G »
hammax wrote: Mon Jul 09, 2018 4:55 pm you are actually working on the GordonSurface-feature (I'm following your CurvesWB-experiments in GitHub)
I got it working on basic test-files tonight.
But there are a couple of things to fix still (like closed profiles, like in your picture).
And most important, I would like to check if output surfaces are "watertight-matching" the boundary edges.
