Zolko wrote: ↑Wed Jun 01, 2022 8:25 am
what happens when you open the file in regular FreeCAD (v0.19 or v0.20) ?
The file opens with errors, then the final result is correct.
FreeCAD 0.20 kept the result of the intersections creating the 3D sketches but shows an error on the surface extrusions that gave rise to them.
- FrameFC0-20.png (400.09 KiB) Viewed 10992 times
Version: 0.20.28909 (Git)
Hash: 6beef68ae1
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Locale: French/France (fr_FR)
* Assembly3 0.11.3
* BOLTSFC
* Curves 0.4.3
* DynamicData 2.46.0
* fasteners 0.3.41
* fcgear 1.0.0
* PieMenu
* symbols_library
The errors :
13:45:43 OpenGL version is: 4.6 (4.6.0 - Build 26.20.100.7642)
13:45:43 Run Gui init script
13:45:43 Init: Running FreeCADGuiInit.py start script...
13:45:44 Init: Searching modules...
13:45:45 Init: Initializing C:\Program Files\FC0.20\Mod\AddonManager... done
13:45:46 Init: Initializing C:\Program Files\FC0.20\Mod\Arch... done
13:45:46 Init: Initializing C:\Program Files\FC0.20\Mod\Draft... done
13:45:46 Init: Initializing C:\Program Files\FC0.20\Mod\Drawing... done
13:45:46 Init: Initializing C:\Program Files\FC0.20\Mod\Fem... done
13:45:46 Init: Initializing C:\Program Files\FC0.20\Mod\Idf(InitGui.py not found)... ignore
13:45:46 Init: Initializing C:\Program Files\FC0.20\Mod\Image... done
13:45:46 Init: Initializing C:\Program Files\FC0.20\Mod\Import... done
13:45:46 Init: Initializing C:\Program Files\FC0.20\Mod\Inspection... done
13:45:47 Init: Initializing C:\Program Files\FC0.20\Mod\Material... done
13:45:47 Init: Initializing C:\Program Files\FC0.20\Mod\Measure(InitGui.py not found)... ignore
13:45:47 Init: Initializing C:\Program Files\FC0.20\Mod\Mesh... done
13:45:47 Init: Initializing C:\Program Files\FC0.20\Mod\MeshPart... done
13:45:47 Init: Initializing C:\Program Files\FC0.20\Mod\OpenSCAD... done
13:45:47 Init: Initializing C:\Program Files\FC0.20\Mod\Part... done
13:45:47 Init: Initializing C:\Program Files\FC0.20\Mod\PartDesign... done
13:45:47 Init: Initializing C:\Program Files\FC0.20\Mod\Path... done
13:45:47 Init: Initializing C:\Program Files\FC0.20\Mod\Plot(InitGui.py not found)... ignore
13:45:47 Init: Initializing C:\Program Files\FC0.20\Mod\Points... done
13:45:47 Init: Initializing C:\Program Files\FC0.20\Mod\Raytracing... done
13:45:47 Init: Initializing C:\Program Files\FC0.20\Mod\ReverseEngineering... done
13:45:47 Init: Initializing C:\Program Files\FC0.20\Mod\Robot... done
13:45:47 Init: Initializing C:\Program Files\FC0.20\Mod\Show(InitGui.py not found)... ignore
13:45:47 Init: Initializing C:\Program Files\FC0.20\Mod\Sketcher... done
13:45:47 Init: Initializing C:\Program Files\FC0.20\Mod\Spreadsheet... done
13:45:48 Init: Initializing C:\Program Files\FC0.20\Mod\Start... done
13:45:48 Init: Initializing C:\Program Files\FC0.20\Mod\Surface... done
13:45:48 Init: Initializing C:\Program Files\FC0.20\Mod\TechDraw... done
13:45:48 Init: Initializing C:\Program Files\FC0.20\Mod\Test... done
13:45:48 Init: Initializing C:\Program Files\FC0.20\Mod\Tux... done
13:45:48 Init: Initializing C:\Program Files\FC0.20\Mod\Web... done
13:45:48 Init: Initializing C:\Users\Bienvenue\AppData\Roaming\FreeCAD\Mod\Assembly3\.\(InitGui.py not found)... ignore
13:45:48 Init: Initializing C:\Users\Bienvenue\AppData\Roaming\FreeCAD\Mod\BOLTSFC(InitGui.py not found)... ignore
13:45:48 Init: Initializing C:\Users\Bienvenue\AppData\Roaming\FreeCAD\Mod\Curves\.\(InitGui.py not found)... ignore
13:45:48 Init: Initializing C:\Users\Bienvenue\AppData\Roaming\FreeCAD\Mod\DynamicData\.\... done
13:45:48 Init: Packaged workbench DynamicData specified icon in class DynamicDataWorkbench ... replacing with icon from package.xml data.
13:45:48 Init: Initializing C:\Users\Bienvenue\AppData\Roaming\FreeCAD\Mod\fasteners\.\... done
13:45:48 Init: Initializing C:\Users\Bienvenue\AppData\Roaming\FreeCAD\Mod\fcgear\.\(InitGui.py not found)... ignore
13:45:48 Init: Initializing C:\Users\Bienvenue\AppData\Roaming\FreeCAD\Mod\PieMenu... done
13:45:49 Init: Initializing C:\Users\Bienvenue\AppData\Roaming\FreeCAD\Mod\symbols_library(InitGui.py not found)... ignore
13:45:49 All modules with GUIs using InitGui.py are now initialized
13:45:49 Init: Initializing freecad.asm3
13:45:49 Module: Part
13:45:49 Loading Part module... done
13:45:53 Init: Initializing freecad.asm3... done
13:45:53 Init: Initializing freecad.gears
13:45:53 Init: Initializing freecad.gears... done
13:45:53 Init: Initializing freecad.Curves
13:45:53 Init: Initializing freecad.Curves... done
13:45:53 Init: Initializing freecad.freecad_glider
13:45:53 Init: Initializing freecad.freecad_glider... done
13:45:53 All modules with GUIs initialized using pkgutil are now initialized
13:45:53 Init: Loading FreeCAD GUI
13:45:53 Init: Running FreeCADGuiInit.py start script... done
13:45:55 Init: Activating default workbench StartWorkbench
13:45:55 Loading GUI of Web module... done
13:45:55 Loading GUI of Start module... done
13:45:55 Loading Start module... done
13:45:55 Installed Qt WebEngine locales directory not found at location C:/Program Files/FC0.20/translations\qtwebengine_locales. Trying application directory...
13:45:55 Qt WebEngine locales directory not found at location C:/Program Files/FC0.20/bin\qtwebengine_locales. Trying fallback directory... Translations MAY NOT not be correct.
13:45:55 Init: Showing main window
13:45:55 Main window restored
13:45:55 Show main window
13:45:55 Toolbars restored
13:45:55 3Dconnexion device not attached.
13:45:55 Init: Entering event loop
13:45:55 Init: Executing event loop...
13:45:56 Init: Processing command line files
13:46:30 Loading Sketcher module... done
13:46:30 Loading PartDesign module... done
13:46:30 Loading GUI of Part module... done
13:46:30 Loading GUI of Sketcher module... done
13:46:30 Loading GUI of PartDesign module... done
13:46:30 Cannot create object 'Extrusion': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion001': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion002': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion003': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion008': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion009': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Loading Image module... done
13:46:30 Loading GUI of Image module... done
13:46:30 QFSFileEngine::open: No file name specified
13:46:30 Cannot create object 'Import': ('Part::SubShapeBinder' is not a document object type)
13:46:30 Cannot create object 'Extrusion004': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion005': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion006': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion007': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion010': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion011': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion012': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion013': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion014': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion015': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion016': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion017': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion018': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion019': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion020': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion021': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion022': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion023': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion024': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion025': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion026': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion027': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion028': ('PartDesign::Extrusion' is not a document object type)
13:46:30 Cannot create object 'Extrusion029': ('PartDesign::Extrusion' is not a document object type)
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Import while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion001 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion002 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion003 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion008 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion009 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion001' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion002' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion003' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion008' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion009' while loading, maybe an object was not loaded correctly
13:46:30 Lost link to 'Import' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion004 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion005 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion010 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion011 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion012 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion013 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion014 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion015 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion006 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion007 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion004' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion005' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion007' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion006' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion010' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion011' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion012' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion013' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion014' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion015' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion016 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion017 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion018 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion019 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion020 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion021 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion022 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion023 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion024 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion025 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion026 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion027 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion028 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(795): Lost link to Motorcycle_Frame Extrusion029 while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion016' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion017' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion018' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion019' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion020' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion021' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion022' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion023' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion025' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion024' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion027' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion026' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion028' while loading, maybe an object was not loaded correctly
13:46:30 <PropertyLinks> PropertyLinks.cpp(3425): Lost link to 'Extrusion029' while loading, maybe an object was not loaded correctly
13:46:53 Enumeration index -1 is out of range, ignore it
13:46:53 1e-07 <App> Document.cpp(2876): Motorcycle_Frame#Reference002.Support: Link not restored
Object: Extrusion002
13:46:53 6.46e-05 <App> Document.cpp(2876): Motorcycle_Frame#Reference003.Support: Link not restored
Object: Extrusion003
13:46:53 9.67e-05 <App> Document.cpp(2876): Motorcycle_Frame#Reference.Support: Link not restored
Object: Extrusion
13:46:53 0.0001107 <App> Document.cpp(2876): Motorcycle_Frame#Reference001.Support: Link not restored
Object: Extrusion001
13:46:53 SketchObject::onChanged(): Unmanaged change of Constraint Property results in invalid constraint indices
13:46:53 0.0053659 <App> Document.cpp(2876): Motorcycle_Frame#Reference015.Support: Link not restored
Object: Extrusion008
13:46:53 0.0053861 <App> Document.cpp(2876): Motorcycle_Frame#Reference016.Support: Link not restored
Object: Extrusion009
13:46:53 0.0104285 <App> Document.cpp(2876): Motorcycle_Frame#Reference004.Support: Link not restored
Object: Extrusion004
13:46:53 0.0104473 <App> Document.cpp(2876): Motorcycle_Frame#Reference005.Support: Link not restored
Object: Extrusion005
13:46:53 0.0109176 <App> Document.cpp(2876): Motorcycle_Frame#Reference006.Support: Link not restored
Object: Extrusion007
13:46:53 0.0109346 <App> Document.cpp(2876): Motorcycle_Frame#Reference007.Support: Link not restored
Object: Extrusion006
13:46:53 0.0111452 <App> Document.cpp(2876): Motorcycle_Frame#Reference021.Support: Link not restored
Object: Extrusion012
13:46:53 0.0111608 <App> Document.cpp(2876): Motorcycle_Frame#Reference022.Support: Link not restored
Object: Extrusion013
13:46:53 0.0119243 <App> Document.cpp(2876): Motorcycle_Frame#Reference019.Support: Link not restored
Object: Extrusion010
13:46:53 0.011941 <App> Document.cpp(2876): Motorcycle_Frame#Reference020.Support: Link not restored
Object: Extrusion011
13:46:53 PositionBySupport: TopoDS::Edge
13:46:53 0.0124037 <App> Document.cpp(2876): Motorcycle_Frame#Reference023.Support: Link not restored
Object: Extrusion014
13:46:53 0.01242 <App> Document.cpp(2876): Motorcycle_Frame#Reference024.Support: Link not restored
Object: Extrusion015
13:46:53 0.0156863 <App> Document.cpp(2876): Motorcycle_Frame#Reference064.Support: Link not restored
Object: Extrusion028
13:46:53 0.0157041 <App> Document.cpp(2876): Motorcycle_Frame#Reference065.Support: Link not restored
Object: Extrusion029
13:46:53 0.0174832 <App> Document.cpp(2876): Motorcycle_Frame#Reference062.Support: Link not restored
Object: Extrusion027
13:46:53 0.0174999 <App> Document.cpp(2876): Motorcycle_Frame#Reference063.Support: Link not restored
Object: Extrusion026
13:46:53 0.0182446 <App> Document.cpp(2876): Motorcycle_Frame#Reference060.Support: Link not restored
Object: Extrusion025
13:46:53 0.018261 <App> Document.cpp(2876): Motorcycle_Frame#Reference061.Support: Link not restored
Object: Extrusion024
13:46:53 0.0189721 <App> Document.cpp(2876): Motorcycle_Frame#Reference057.Support: Link not restored
Object: Extrusion022
13:46:53 0.0189888 <App> Document.cpp(2876): Motorcycle_Frame#Reference058.Support: Link not restored
Object: Extrusion023
13:46:53 0.0196739 <App> Document.cpp(2876): Motorcycle_Frame#Reference053.Support: Link not restored
Object: Extrusion020
13:46:53 0.0196897 <App> Document.cpp(2876): Motorcycle_Frame#Reference054.Support: Link not restored
Object: Extrusion021
13:46:53 0.0203567 <App> Document.cpp(2876): Motorcycle_Frame#Reference033.Support: Link not restored
Object: Extrusion018
13:46:53 0.0203736 <App> Document.cpp(2876): Motorcycle_Frame#Reference034.Support: Link not restored
Object: Extrusion019
13:46:53 0.0214276 <App> Document.cpp(2876): Motorcycle_Frame#Reference031.Support: Link not restored
Object: Extrusion016
13:46:53 0.0214446 <App> Document.cpp(2876): Motorcycle_Frame#Reference032.Support: Link not restored
Object: Extrusion017
13:47:31 Loading MeshPart module... done
13:47:31 Loading GUI of MeshPart module... done
13:47:31 Loading Surface module... done
13:47:31 Loading GUI of Surface module... done
13:54:16 Hide main window
13:56:36 Save AutoRecovery file: Needed time: 6s
13:56:36 Show main window
14:00:20 Hide main window
14:03:45 Show main window
14:03:53 Hide main window
14:05:09 Show main window
