Freecad 0.17 - Pad up to face - Datum Plane is invalid
Re: Freecad 0.17 - Pad up to face - Datum Plane is invalid
I think up to selection is better than up to selected object
Well, if you want to use the same term for both, I would keep it short and just go with "Up to object."
- industromatic
it would be good to be able to define specify solids with one or both ends on datum planes. Solids such as cone, cylinder, box.
This seems to me a rather theoretic approach. Do you have a usecase for this? For me it would be enough to attach a sketch to a datum plane and pad it to the next plane.industromatic wrote: ↑Fri Sep 08, 2017 7:25 pm it would be good to be able to define specify solids with one or both ends on datum planes. Solids such as cone, cylinder, box.
Honestly, I don't think "object" is a good term here. Object is too generic, it can mean anything. This mode of padding is intended to go to a face or a plane, not a generic object which in FreeCAD could be a vertex, an edge, a shape etc.
If you want a more generic term, I would go with "Reference", which could be interpreted in the context of the tool. So in the Fillet parameters, a reference could be an edge or a face; in "Pad to...", it would refer to a face or a plane, etc.
Any objections against "Reference"? If not I would include the notion in the bug tracker.
"Object" is a bad idea because you pad to a specific face on an object, not the object itself.
I have had a similar issue: Padding up to a datum plane for a sketch with no underlying solid wasn't allowed (error message regarding zero height as mentioned earlier), but padding from a sketch on the face of an existing solid did work.
However, in the case where it did work, it only half worked... I had created one item on the sketch and then duplicated as a rectangular array (see sketch.png). Only the original sketch item was padded, the others were ignored (see pad breaks with uptoface.png). If I switch from pad UpToBody to Dimension then immediately all items are padded (see pad works with dimension.png).
I see the same problem. Looks like a bug.
OS: Windows 7
Version: 0.18.13705 (Git)
Hash: 891682a41220943af114f1312b57e04401c4cefb
Python version: 2.7.14
Qt version: 4.8.7
OCC version: 7.2.0
OS: Windows 7
Qt version: 4.8.7
OCC version: 7.2.0
I'll write this up as a bug if someone tells me it's not already on the list.
