Silk: a NURBS workbench
microelly2
Re: Silk: a NURBS workbench
Post by microelly2 »
I'm not realy a friend of the surface object. It creates good approximations for the input data but the outcome is not stylish:
the poles grid in this case does not have a relation to the border faces and the face is a patch of the bspline surface.
the waviness of the surface can be smoothed in a second step but it is the result of a brutal interpolation.
I think the task is to find a method which creates for a triangle gab definde by 3 nurbs surfaces a filler consisting of 3 unpatched nurbs.
in my example I used 3 ruled surfaces (along bezier curves) as borders (brown/pink ) and created inside the hole 3 nurbs red, blue green
because there is only a small number of poles and because of the simple bezier curves the continuity is not anywhere 2 but the isocurve structure is naturally. The grid of the inner faces is scaled by factor 2 to show the balanced correlation between the knots of all faces.
for statistics:
the border curves have each 7 poles (two connected bezier curves)
the inner area has 36 poles - each segment is a 4 x 4 bspline surface of degree 3, so all edges are simple bezier curves.
here is my example file
https://www.dropbox.com/s/i6n5sas1ky5c6 ... fcstd?dl=0
emills2
Post by emills2 »
microelly2 wrote: Wed May 23, 2018 8:13 pm I think the task is to find a method which creates for a triangle gab definde by 3 nurbs surfaces a filler consisting of 3 unpatched nurbs.
that's the same strategy i talked about a year ago:
https://forum.freecadweb.org/viewtopic. ... 20#p187547
and that is precisely what i am comparing the filling surface to in my posts above
july 29 2017
Silk has a system that handles N sided patches and gets G2 at the OUTER edges of each 'NStar' (but the center has a slight pinch, and it seems to get worse the more branches the star has)
september 17 2017
they are lightweight and fast, but in my estimation, G1 filling from the surface workbench will often be better overall.
i used N 36 control point patches in N 6X6 cubic NURBS surfaces, and that is as far as i want to push it personally. The inner point placement can be refined, but i spent too much energy already in that. the long term goal for me was always to get the final surface using the OCC filling method. Trimmed fitted surfaces are generally considered the state of the art for odd hole filling, and if we keep scratching, we will uncover how to make the built in G2 functionality work.
july 29 2017
how did you generate your '3 ruled surface example'? can you run it on my 3 border surfaces in the model so we can compare side by side all 3 versions?
PrzemoF
Post by PrzemoF »
emills2 wrote: Tue May 22, 2018 5:16 pm
triplus wrote: Tue May 22, 2018 12:37 pmNice progress.
definitely :) but i certainly don't claim any credit. all i did was sit back and wait for someone else to implement OCC filling.
i think the kayak models can go a lot further now!
:D I hope it will happen soon!
microelly2
emills2 wrote: Thu May 24, 2018 5:41 am
july 29 2017
july 29 2017
Yes I see it, nice to have already an implementation.
I aks me now how to make it easy to use.
Here is my script
ecke_aus_drei_nurbs.py
(5.43 KiB) Downloaded 98 times
phpBB [video]
emills2
Post by emills2 »
microelly2 wrote: Thu May 24, 2018 3:08 pm ping
thanks for the script. it's a lot to digest, so could you load the final surfaces for your 3 piece corner? i'd like to look at them in a bit more detail before trying to understand how your script works.
Silk WB still needs a logo for the add-on Manager
https://github.com/edwardvmills/Silk/issues/10
PR created for new logo on master
https://github.com/FreeCAD/FreeCAD/pull/3128
Also Silk Workbench has been created but needs love
emills2
Post by emills2 »
Kunda1 wrote: Wed Mar 04, 2020 5:11 pm Also Silk Workbench has been created but needs love
can you help me get an account? same username as here would be good.
didn't i hear that the docs were going to move somewhere else? is this the new location or the old one?
Thanks
emills2 wrote: Sat Mar 07, 2020 3:32 am can you help me get an account? same username as here would be good.
Thanks
PM me an email address
There has been talk about moving to a git-based documentation system. But for now we've migrated the Wiki to a more recent version and I've been working on cleaning it up so that maybe when the day arrives and we do migrate to a different documentation framework that it'll be easier to do so.
