Curves workbench
Re: Curves workbench
that works,
nice!!
thanks
nice!!
thanks
now I have another problem.
In the test file I will attach. When I select the lines in order from top to bottom and then the left and last the right line and then try to make a Gordon surface. The whole freecad freezes which leaves two questions:
- why can't I create this gordon?
- it freezes, is this a bug?
thanks,
Karl
thanks,
Karl
- 1.jpg (8.17 KiB) Viewed 1802 times
- test.FCStd
- (14.93 KiB) Downloaded 22 times
Curves must have a grid-like pattern.
The black curve that joins the bulb of the green curve isn't compliant with that requirement.
ok
so how I would connect something like this to a surface?
Post amended to save thread space.
gordon doesn't like this kind of corner.
it's better to use filling feature for a flat surface here.
- Capture.JPG (20.83 KiB) Viewed 1636 times
Post amended to save space on thread.
I am trying to make a simple curved object. It is a wingtip but it could be a boat or canoe. I want to parameterize it with a spreadsheet. I have tried several approaches. Using a ruled surface, sweep2rails, and Approximate works but only to the outer profiles. I can not get the point cloud to extend to the front and back (bow & stern). Sometimes the Gordan surface works and sometimes it fails. Often when it fails, it gives the spinning wheel and requires killing freecad.
I would certainly appreciate any suggestions on a workflow for creating this type of object. I suspect, there are restrictions on the bow and stern profiles but I don't currently understand them.
Thanks,
Thanks,
OS: Arch Linux
Version: 0.21.0.31917 (Git) AppImage
Hash: 4639283b459f9ff9093e289908cc003db8745b82
Python 3.10.9, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
* Plot 2022.4.17
* Curves 0.6.5
* AirPlaneDesign 0.4.0
* CurvedShapes 1.0.4
- WingTip5.FCStd
- (610 KiB) Downloaded 27 times
For Gordon surface you need to have a grid-like pattern :
viewtopic.php?t=29632&start=70#p280130
Same for the approximate tool, where you must provide a list of objects that all contain the same amount of points.
Surfaces that degenerate to a single point at the ends are not supported.
Both tools can only generate curved rectangles (= with 4 sides).
Have you looked at this thread? viewtopic.php?p=665470#p665470
