I would like to draw a curves_line between two of the points on the BSpline (not the end points).
I somehow don't manage. When I select two points and click the button for the curves_line nothing happens.
karlsinn wrote: ↑Sat Mar 04, 2023 12:59 pm
Select the blue line between the 2 points instead.
Hmm...I don't get it. I thought there are 2 freehand splines, each with say 3 verts. And the question was how to draw a curves_line between the middle verts of the freehand. But the Freehand is in edit mode.
next question.
I have 2 connected splines (picture 3).
Now I would like to split one of the lines (picture 2) in two parts at the point of attachment of the other spline.
When I use split_curve I can move the point where it splits through the editor (picture 1), but I need it to be exactly at the attachment point of the second spline.
How can I move the split point exactly there?
thanks,
Karl
If I understand your need correctly.
You select the 2 points by holding the "Ctrl" key and you click on the "S" key.
Now the curves will be connected at the level of the point.
- Select the edge you want to split in the 3D View
- Activate the Split_Curve tool
- Remove the 50% value (but leave the brackets) in the Values property
- Clic the [...] button in the Cutting Objects property
- Select the cutting edge in the 3D View + OK
