Curves workbench
Re: Curves workbench
hammax wrote: Tue Feb 28, 2023 12:03 pm I found, that creating a Sketcher-BSpline inside an empty Sketch from Sketch on Surface, didn't work.
I cannot confirm. I took your file, selected the surface of the cylinder and applied SketchOnSurface.
Then I clicked Sketcher CompCreateBSpline and I had no problems to place the control points with the mouse.
OS: macOS 10.16
Version: 0.21.0.31917 (Git)
Hash: 4639283b459f9ff9093e289908cc003db8745b82
Python 3.10.9, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: C/Default (C)
  * FC_SU
  * DynamicData 2.46.0
  * freecad.gears 1.0.0
  * FeedsAndSpeeds 0.5.0
  * dxf-library
  * fcgear 1.0.0
  * fasteners 0.4.54
  * sheetmetal 0.2.61
  * ExplodedAssembly
  * Curves 0.6.8
Chris_G
Post by Chris_G »
When executed, Sketch_on_surface removes internal geometries.
So if you need to modify a BSpline afterwards, you must select it and do Sketch tools -> Show/hide internal geometries.
But the best workflow is definitely to keep only the blue rectangle in the Mapped_Sketch and use another sketch in the Extra Objects property for the shapes you want to map.
Bernard19
Post by Bernard19 »
Good morning,
I present my problem to you. From a volume obtained between Gordon and Surface how can I create a thickness in this part. I created a solid with the Solid/Curves icon but it is not recognized in Part. So creating a Solid with the Convert to Solid/Part function. Unable to perform a Tickness under Part.
My solution: I made a copy of my object, then Draft/Scale and Ruled_Surface to tie it all together.
Is there a method to more simply generate a thickness
Cordially
Capture d'écran 2023-03-03 121531.png (47.18 KiB) Viewed 1125 times
Curves_Thickness.FCStd
(485.15 KiB) Downloaded 15 times
hammax
Post by hammax »
... a possible solution by generating Link.
The body can be scaled.
Curves_Thickness_2.FCStd
FC.20.1
(139.24 KiB) Downloaded 18 times
Bernard19
Post by Bernard19 »
Really very good. I'm new to the Curves workshop, so I have a few subsidiary questions.
1- Why use the Cube after the Offset?
2- Is't better to make a Common than a Connect?
3- After using a construction by FreeHand, how to be sure that the part generated with Gordon will be contiguous during a symmetry?
Excuse me for my English
Cordially
hammax
Post by hammax »
... experiment with it and you'll see, it is tricky.
1. without using common, the cone has oblique rims, you must cut off by common with plane cube faces.
2. see 1.
3. Link mirroring by axis scaling +/- or even a scale factor (right click) "show all" in Data Tab.
Link has a lot more features intus.
Bernard19
Post by Bernard19 »
@hammax
Thanks you
Can you suggest me a site or a support because the wiki does't document all the icons of Curves WB
edwilliams16
Post by edwilliams16 »
Mangojelly's videos on the Curves WB is good: https://www.youtube.com/playlist?list=P ... lpYPiEKMmC
He's also good on the Lattice2 WB.
csirkecsontocska
Post by csirkecsontocska »
Hi guys!
I would like to ask for some help. I have this annoying issue with Freehand_BSplines. When I try to edit a spline FreeCAD randomly throws an indexing error:
...gordon_profile_FP.py", line 221, in setEdit
    pts.append(profile_editor.MarkerOnShape([p], sl[shape_idx]))
<class 'IndexError'>: list index out of range
After this, it is impossible to get in edit mode ever again for the given spline. The only solution is to delete the spline and create another instead. I attached my file. You can check this issue with Freehand_BSpline107 if you want.
What am I doing wrong?
Thank you!
  * CfdOF 1.21.4
  * Curves 0.6.6
  * ExtremeProDark 2.6.4
fiat.FCStd
(409.59 KiB) Downloaded 14 times
karlsinn
Post by karlsinn »
I would like to draw a curves_line between two of the points on the BSpline (not the end points).
I somehow don't manage. When I select two points and click the button for the curves_line nothing happens.
What's my mistake?
thanks,
Karl
OS: openSUSE Leap 15.4 (XFCE/xfce)
Version: 0.21.0.31917 (Git) AppImage
  * Curves 0.6.7
  * fasteners 0.4.23
