Curves workbench
Re: Curves workbench
@Chris_G
Curves|Parametric Line appears not to respect links. If I try to connect vertices of two different linked objects, the line is created in the original.
- parametricline.FCStd
- (6.22 KiB) Downloaded 34 times
... Links can be connected by Parametric_Lines.
Maybe it's a bug with DraftWB Array ??
- parametricline_2.FCStd
- FC.20.1
- (11.34 KiB) Downloaded 22 times
Issue #80edwilliams16 wrote: ↑Mon Mar 13, 2023 9:24 pm @Chris_G
It's very hard to trim this face (with the trim feature) in this case because the selection is on the face. It should be easy by selecting the sketch or object in the treeview.
What you think about that?
- VeryHard2Trim.FCStd
- (11.51 KiB) Downloaded 26 times
how to get a nice extend of an helix curves? should extend feature has frenet option?
- extend_helix.FCStd
- (15.25 KiB) Downloaded 35 times
I've not tried this before - but this works...
Hide face
Select the edges of the cutting hexagon
Curves|Join curves
Unhide face
select face and join_curves
Curves|Trim face
- thomas-neemann
When I work with solid, the colors disappear for me. Is there a way to adopt the colors?
What do you mean ?
It turns grey ? The icon disappears ?
where ?
On the toolbar icon ? On an object icon ?
where ?
- thomas-neemann
ParametricBlendCurve seems to have an issue after commit: "0f886a2 BlendCurve: allow datum lines".
Here is an example before the commit (using 2af0d6e): Here's what happens after and currently:
