GD&T Workbench for FreeCAD
Re: GD&T Workbench for FreeCAD
I try to bring it back to life ... FreeCad 0.20
I have at least the icons and the basic functions ... after that the code will have to be totally redone ...
If someone is motivated :
https://github.com/5axes/FreeCAD-GDT
Nice, i really like the idea to dimension all in 3D.
Greetings
user1234
Greetings
user1234
I'm using Freecad 0.20.1
For the moment my goal was just to see if we could reactivate this WB for the current version of FreeCad. Having never seen the Module working , it was difficult to see the level reached before the development was stopped. I thought that the functions were much more advanced. Finally the work to be done is huge but if we don't try to reignite a little spark this will never progress.
Looking at the screenshots of the original Github we can see a coding of the GPS features that doesn't seem to be possible in the existing code.
Would the creator have left on his Github a less finished version of his code I don't know and I think we will never get the info. For the moment the basic level of the plugin is not a problem because it is the right sandbox to advance in the specifics of writing a WorkBench for FreeCad.
In the creation of Features I have a warning message from FreeCad that tells me :
Someone has an idea of what is not well defined ?
App::FeaturePython: Link(s) to object(s) 'Pad' go out of the allowed scope 'AnnotationPlane'. Instead, the linked object(s) reside within 'Body'.
Unfortunately everything is there. or almost I did not find how to put the 2X . But I find what we had in the first screenshots of this post.
- pref.png (38.46 KiB) Viewed 1348 times
Should be 0.05 mm and not 50 'Microns'
It is only a warning. You reference elements (face, lines, vertex) from features (in that case probably Pocket001), not the whole Body, outside the Body. This means when you add a feature to the Body (for example a fillet), it will not be considered. It still references to the not last visible feature.
Greetings
user1234
edit: typo
