GD&T Workbench for FreeCAD
Cuq
Re: GD&T Workbench for FreeCAD
Post by Cuq »
easyw-fc wrote: Thu Mar 16, 2023 2:00 pm Would you mind to develop on FC0.21 next stabile ?
I tested but obviously the code is not compatible with the 0.21
  File "GDT.py", line 242, in showGrid
    FreeCADGui.Snapper.show()
  File "FreeCAD 0.21\Mod\Draft\draftguitools\gui_snapper.py", line 1570, in show
    toolbar = self.get_snap_toolbar()
  File "FreeCAD 0.21\Mod\Draft\draftguitools\gui_snapper.py", line 1505, in get_snap_toolbar
    action = Gui.Command.get(cmd).getAction()[0]
list index out of range
Something to do with get_snap_toolbar or FreeCADGui.Snapper.show() !
Cuq
Post by Cuq »
Cuq wrote: Fri Mar 31, 2023 1:13 pm
Temporarily solved by modifying Draft\draftguitools\gui_snapper.py
Freecad 0.20
    def get_snap_toolbar(self):
        """Returns snap toolbar object."""
        mw = Gui.getMainWindow()
        if mw:
            toolbar = mw.findChild(QtGui.QToolBar, "Draft Snap")
            if toolbar:
                return toolbar
        return None
Freecad 0.21
        """Get the snap toolbar."""
        if not (hasattr(self, "toolbar") and self.toolbar):
            self.toolbar = mw.findChild(QtGui.QToolBar, "Draft snap")
        if self.toolbar:
            # Make sure the Python generated BIM snap toolbar shows up in the
            # toolbar area context menu after switching back to that workbench:
            self.toolbar.toggleViewAction().setVisible(True)
            return self.toolbar
        # Code required for the BIM workbench which has to work with FC0.20
        # and FC0.21/1.0. The code relies on the Snapping menu in the BIM WB
        # to create the actions.
        self.toolbar = QtGui.QToolBar(mw)
        mw.addToolBar(QtCore.Qt.TopToolBarArea, self.toolbar)
        self.toolbar.setObjectName("Draft snap")
        self.toolbar.setWindowTitle(translate("Workbench", "Draft snap"))
        for cmd in get_draft_snap_commands():
            if cmd == "Separator":
                self.toolbar.addSeparator()
            else:
                self.toolbar.addAction(action)
        return self.toolbar
Freecad 0.21 Modified
        if self.toolbar:
            return self.toolbar
        try:
                else:
        except:
            return None
        return self.toolbar
Roy_043
Post by Roy_043 »
Cuq wrote: Fri Mar 31, 2023 2:05 pmFreecad 0.21
This is not the current V0.21 code.
Cuq
Post by Cuq »
There is certainly a newest code . But for me it was the Last Code installed from the Code coming from the weekly-builds : 2023/03/16 19:25:33
https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
Roy_043
Post by Roy_043 »
You must have made a copy-paste error:
        try:
Cuq
Post by Cuq »
Addition of the Additional symbols :
Derived toleranced feature specification elements
Derived feature -> A ISO 1101 04/2017 Clause 6 and 8.2.2.2.3
Associated toleranced feature specification element
Minimax (Chebyshev) feature -> C ISO 1101 04/2017 8.2.2.2.2
Least squares (Gaussian) feature -> G ISO 1101 04/2017 8.2.2.2.2
Minimum circumscribed feature -> N ISO 1101 04/2017 8.2.2.2.2
Maximum inscribed feature -> X ISO 1101 04/2017 8.2.2.2.2
Note : Works only with Iso-Gps Font
easyw-fc
Post by easyw-fc »
Cuq wrote: Fri Mar 31, 2023 1:13 pm I tested but obviously the code is not compatible with the 0.21
it seems now it is working... thanks for your work :D
Cuq
Post by Cuq »
Kunda1 wrote: Sun Apr 16, 2023 2:50 pm @Cuq see https://github.com/FreeCAD/FreeCAD-addo ... 1510361387
Still working on, but not ready to become the official maintainer of this WB.
maxwxyz
Post by maxwxyz »
How can I install this new fork? I cannot find it in the addon manager.
