OCC Bugs in the Bugtracker
- adrianinsaval
Re: OCC Bugs in the Bugtracker
Please create a new topic or GitHub issue for this, including full version information, please also check if you are using a hi dpi monitor or not
We had something similar recently here. Is Preferences->Display->3D View ->Transparent objects set to "One pass"?
You may try to switch it to and fro (with intermediate saving) or go right away for deleting the whole config file.
I've renamed my user.conf file and restarted FreeCAD, the glitch is still there. Changing the transparent object setting makes no difference - the arrows are visible with both settings. If I select "Hide base length units for supported unit systems" the numeric value for the dimension is still cut off.chrisb wrote: ↑Tue May 09, 2023 11:07 pm Here are some other discussions concerning the topic:
viewtopic.php?p=433444
viewtopic.php?t=70975
Do I start a new thread on this one?
- adrianinsaval
Yes please, that has nothing to do with occ
Just checked and there is no visibly upstream activity on any of the relevant pending tickets.
OCCT v7.7.2 has been tagged https://git.dev.opencascade.org/gitweb/ ... 9e8dfa85e2
