Importing a SVG to a different plane/axis.
pperrin
Post by pperrin »
I have two SVGs a plan and side view - I want to import them extrude them and do a boolean operation on them...
But the SVGs are a bit messed up - at random coordinates.
I think I can use draft move to bring them together, and move them to the origin, but one needs to be rotated and flipped into the vertical plane...
I could move/rotate in another program, but can't change planes and would really prefer to do the fiddling in freecad.
Can this work?
pperrin
Re: Importing a SVG to a different plane/axis.
Post by pperrin »
OK started programming some stuff to turn parts into sketches...
Then found out more about the draft workbench - once I'd worked out the working plane stuff it was easy to do with no programming(!).
Thanks anyway!
PitiBon
Post by PitiBon »
I don't know how to program and I don't want to go in a rabbit hole.
I just want to designate the plane for an svg import, FreeCAD doesn't show me an option but arbitrarily selects a plane that I don't know how to change later.
Help?
Roy_043
Post by Roy_043 »
Put the objects in a Std_Part and manipulate its Placement.
pperrin wrote: Wed Jan 18, 2017 8:43 pm Can this work?
Whenever I import an SVG it is in XY plane. If they are in a different plane at yours, do They still have the Placement (0,0,0)?
