How to activate openCamLib after compiling it
DarkPhoinix
Re: How to activate openCamLib after compiling it
Post by DarkPhoinix »
Hi all,
I have a trouble with opencamlib:
cmake txt:
/Use Python V3
USE_PY_3:BOOL=ON
version:
OS: Ubuntu 18.04.2 LTS
Version: 0.18.1.
Python version: 3.6.7
Qt version: 5.9.5
Locale: Italian/Italy (it_IT)
lib dir:
pappo@pappo-VirtualBox:/usr/local/lib/opencamlib$ ls -l
totale 1356
lrwxrwxrwx 1 root root 21 mag 5 12:49 libocl.so -> libocl.so.2018.08.122
-rw-r--r-- 1 root root 1387680 mag 5 12:47 libocl.so.2018.08.122
upgrade pip setuptools:
root@pappo-VirtualBox:/home/pappo/opencamlib/build# pip3 install --upgrade setuptools
Collecting setuptools
Downloading https://files.pythonhosted.org/packages ... ne-any.whl (575kB)
100% |████████████████████████████████| 583kB 2.0MB/s
Installing collected packages: setuptools
Found existing installation: setuptools 39.0.1
Not uninstalling setuptools at /usr/lib/python3/dist-packages, outside environment /usr
Successfully installed setuptools-41.0.1
etc:
pappo@pappo-VirtualBox:/$ cat /etc/ld.so.conf.d/libc.conf
# libc default configuration
/usr/local/lib
python 3 shell import libocl ocl OCL:
Python 3.6.7 (default, Oct 22 2018, 11:32:17)
[GCC 8.2.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import libocl
File "<stdin>", line 1, in <module>
ModuleNotFoundError: No module named 'libocl'
>>> import ocl
ModuleNotFoundError: No module named 'ocl'
>>> import OCL
ModuleNotFoundError: No module named 'OCL'
pip3:
root@pappo-VirtualBox:/home/pappo/opencamlib/build# pip3 install libocl.so
Collecting libocl.so
Could not find a version that satisfies the requirement libocl.so (from versions: )
No matching distribution found for libocl.so
The problem is Python3? Wrong version of gcc and g++? need to put any file in Mod dir ?
DarkPhoinix
sliptonic
Post by sliptonic »
It's not that we're ignoring your post. The rest of this thread deals with essentially this same issue. There's an installation issue related to Python3 and we don't have a solution yet.
DarkPhoinix
sliptonic wrote: Wed May 08, 2019 2:38 am It's not that we're ignoring your post. The rest of this thread deals with essentially this same issue. There's an installation issue related to Python3 and we don't have a solution yet.
Thank you very much, now I know it's not my fault!
Erich Schulz
Post by Erich Schulz »
Is there a wiki page on ocl?
If not, should their be?
Russ4262
Post by Russ4262 »
Good morning,
Erich Schulz wrote: Tue Jun 04, 2019 10:27 pm Is there a wiki page on ocl?
Current information about OCL within the wiki is here: Path Surface.
chrisb wrote:ping
However, I think it needs to be relocated to the Path 3D Surface wiki page.
Russ
kkremitzki
Post by kkremitzki »
It wouldn't hurt to have a page specifically for it (how to build it on different platforms, integration/usage notes etc) while the situation with its packaging gets taken care of.
Erich Schulz
Cool. I have been bold and started a stub
Erich Schulz
stub is here:
https://www.freecadweb.org/wiki/OpenCamLib
it would probablly benefit from other's experience
As OCL may be used from different operations it should indeed live in its own page, which can then be referenced. Erich, can you please move the stuff from 3D Surface to the new page?
