How to activate openCamLib after compiling it
nemesis
Re: How to activate openCamLib after compiling it
Post by nemesis »
hi,
check your CMakeCache.txt file you should turn on python 3
//Use Python V3
USE_PY_3:BOOL=ON
quick61
Post by quick61 »
nemesis wrote: Thu May 02, 2019 5:30 pm hi,
//Use Python V3
USE_PY_3:BOOL=ON
Thanks for the tip, but no joy. A complete clean new clone of the repo, used cmake-gui and turned on the USE_PY_3, turned off the BUILD_CXX_LIB and again, it builds with and installs in python2.7. Like I said, it shouldn't be this hard.
Mark
This post made with 0.0% Micro$oft products - GOT LINUX?
kkremitzki
Post by kkremitzki »
I think the problem is actually in your system Boost library and some of its settings being picked up by the OCL build. For example, on Debian Unstable, following the same instructions, I can get a Python 3 build.
nemesis
Post by nemesis »
quick61 wrote: Thu May 02, 2019 6:21 pm . Like I said, it shouldn't be this hard.
Mark
kkremitzki wrote: Thu May 02, 2019 6:41 pm on Debian Unstable
Yep
Debian Unstable here also (but indeed quite stable :lol: )
OS: Debian GNU/Linux buster/sid (KDE//usr/share/xsessions/plasma)
Version: 0.19.16540 (Git) AppImage
Hash: 554985dede771f9a6694baba2372cc60db86f17b
Python version: 3.7.1
Qt version: 5.6.2
Locale: French/France (fr_FR)
quick61
Post by quick61 »
Well that just figures, my stupid furry rear end on an LTS... maybe I'll try back again next year.
sliptonic
Post by sliptonic »
I was having this exact problem on Linux Mint 19. Never found a solution.
I ended up building on debian buster to work around it.
I really hope we find a fix.
kkremitzki
quick61 wrote: Thu May 02, 2019 7:36 pm Well that just figures, my stupid furry rear end on an LTS... maybe I'll try back again next year.
If you're feeling brave, you could install sudo apt install virt-manager and try testing things inside a VM which would let you keep your stable system intact while still letting you try new features.
kkremitzki
bill
Post by bill »
herbk wrote: Wed Apr 24, 2019 7:45 pm Hi huegene,
huegene wrote: Wed Apr 24, 2019 6:30 pm Hi,
is it possible that you try to import opencamlib as: import OCL instead of: import ocl?
kind regards
huegene
I did, but get`s the same error..
:D herbk, try to "locate" ocl.so like follows:
... to see if it is successfully installed at least/and where!
herbk
Post by herbk »
Hi Bill,
i know where it is,- only newer FC not... :lol:
At an other PC i have still a early FC 0.17 which find ocl. A 0.18 AppImage at the same machine don-t find it.
I'm in mind, that the message is missleading... New FC Versions also find OCL, but can't work with it.
Gruß Herbert
