Obj import not visible
dbuursma
Post by dbuursma »
My imported Obj file is not visible in FreeCad. There are mtl files in the same folder, but somehow no details..
Can someone help?
Thanks,\
Douwe
OS: Windows 10
Version: 0.16.6704 (Git)
Branch: releases/FreeCAD-0-16
Hash: 0c449d7e8f9b2b1fb93e3f8d1865e2f59d7ed253
Python version: 2.7.8
Qt version: 4.8.7
OCC version: 6.8.0.oce-0.17
NormandC
Re: Obj import not visible
Post by NormandC »
Hello Douwe,
dbuursma wrote:Can someone help?
Can you provide a link to download the OBJ file, or join it to this topic? Under the "Save draft" "Preview "Submit" buttons, there is an "Attachments" tab that allows you to upload images and files.
dbuursma
Post by dbuursma »
Sorry, file is too large, 9Mb. I have made it available at: http://www.verstralershop.nl/media/free ... j_2011.zip
NormandC
Post by NormandC »
I confirm that the file can be opened in FreeCAD, but that nothing shows in the 3D view. There's no message in the Python console nor the report view. The Data tab reports no point, edge or face. :?
It opens without trouble in Blender...
I hope a FreeCAD developer can tell us what's wrong.
BTW it's an impressive model!
NormandC
Post by NormandC »
Here's a workaround:
  1. Install and launch Blender
  2. Blender creates a new document with a cube already selected. Delete it with the Delete key on your keyboard, CLick on "Delete" in the contextual menu
  3. Go to File --> Import --> Wavefront (.obj)
  4. Browse to your OBJ file, select it, click on "Import OBJ"
  5. Go to File --> Export --> Wavefront (.obj)
  6. In the left panel, under "Export OBJ", at the very bottom, choose the following orientation for the model:
    Forward: -Y forward
    Up: Z up
  7. Click on the "Export OBJ" button.
This will create a new OBJ file that will open correctly in FreeCAD. Beware, it will take a long time to load, and create multiple mesh objects.
dbuursma
Post by dbuursma »
Thanks, worked!
It fails to load because the point indices of the faces are all negative but FreeCAD doesn't support this way at the moment.
NormandC
Post by NormandC »
Thanks Werner.
keithsloan52
Post by keithsloan52 »
Have the same issue with a couple of Obj files.
OS: Ubuntu 18.04.4 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Python version: 3.6.9
Qt version: 5.9.5
humanoid_tri.obj
(3.24 KiB) Downloaded 37 times
humanoid_quad.obj
(2.89 KiB) Downloaded 36 times
Files load into Blender & MeshLab okay
