URDF Workbench, robotics
fosselius
Re: URDF Workbench, robotics
Post by fosselius »
Gazebo/SDF wants the models to have its model origo at the center of mass.
This was just me getting my center of inertia at origo while the model had its origo at a random position (not center off mass or a corner).
I am not looking for a "perfect solution" i am only looking for an easy/fast way to test different mechanical links in gazebo.
I would like to design a passive dynamic walker and experiment with different mechanical linkage to generate different gaits ;)
I have looked at the blender plugin and it looks very potent, but that is not what i need.
fosselius
Post by fosselius »
I have managed to load exported a SDF with two links in Gazebo. Each body becomes a link. Its still very rough and the .stl export is not included yet.
But you can follow the progress here: https://github.com/maidenone/RobotCreator
There is not much to see yet and its not yet ready for testing.
Also the name is not that great, might be confused with the Robotic Workbench. But the "URDF or SDF" workbench is not entirely correct either, and "Gazebo workbench" is also not entirely correct.
Thanks for the update! 8-)
fosselius
Post by fosselius »
ok, now we have a little progress
phpBB [video]
fosselius
Post by fosselius »
Here is an small update, progress is slow as usual, but now i have something that can export to SDF with 3d shapes and joints.
Joints are created by selecting two objects and then running the "createHingeJoint" script that will create a joint object that keeps track of parent/child, position, orientation as well as initial angle of joint.
The "exportToSDF" script then later finds all the joint objects and inserts them as joints in the SDF file.
I actually had this done a few months ago, but have not bothered with the GUI work until now.
I have also looked a bit on BulletPhysics, Right now i export and simulate in Gazebo, but it would be more efficient to set upp Bullet to be able to run directly in FreeCAD as done here: https://github.com/JMG1/FreeCAD_BulletPhysics
It should not be much work as Bullet can import SDF and URDF directly, so next up would be joint control.
Screenshot from 2017-10-05 21-17-27.png (24.25 KiB) Viewed 7216 times
Screenshot from 2017-10-05 21-18-04.png (56.02 KiB) Viewed 7216 times
If i keep this up i will probably have something that looks/works well around 2020 ;)
fosselius
Post by fosselius »
I made a new video to better show the current status of the project:
phpBB [video]
rupkin
Post by rupkin »
Hi fosselius!
Would it be possible to give a license to your project like BSD or MIT?
I'd like to test it but mustn't use it until it is licensed.
Thanks!
fosselius
Post by fosselius »
Its just a buch of lines of python. You can consider it "Public Domain". I am on vaccation at sea and have no access to a cumputer and only sporadic internet on my phone. I can add the proper licence docunent in the project once i get back.
Project is here:
Its in a very "hacky" state and might not work at all.
I started to play around with loading the URDF or SDF directly into pyBullet and render it inside freecad to be able to run the physics simulations directly in the same program. But i ran out of time and motivation.
I have considered to reimplement it based on realthunders assembly fork but are waiting for it to be merged into freecad master first which can take months if not years at the current phase.
Currently i think working on realthunders fork if is the best way yo spend my spare time and when the solver works well i can start with the robot "rigging, simulation and coding/control".
I would like to get something with as few dependencies as possible and not force users to install Gazeboo and ROS in order to do simulation or joint control. But i still want to have an easy workflow to modify sdf/urdf for use in ROS and Gazeebo if needed.
Interesting related robotics thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=10425 (Gypsy - A long term personal project for fun.)
kaalatrie
Post by kaalatrie »
Hi, Is anyone still working on the robotics package for freecad? Please connect with me if yes. I am very interested in this and I want to know if anyone would be interested as well or are already working on it. Thank you!.
