Help for first steps within the wiki
catman
Re: Help for first steps within the wiki
Post by catman »
cds4byu wrote: Sun Feb 25, 2018 10:38 am There is one command in the source that I don't understand:
<!--T:8-->
Is this syntax explained anywhere? I've searched the wiki and the forums, and I can't see it explained.
I have now found that this is translation infrastructure that is automatically added. I should not modify these when I am updating the page. For more information, see https://www.mediawiki.org/wiki/Help:Ext ... on_example
I had the same problem, but I was not aware other have it as well. I think that information should go to the wiki. The best place I figured was the
WikiPages:Before Starting
I added a section on what I understood. Please review the text (https://www.freecadweb.org/wiki/WikiPag ... e_Starting) and tell me what is wrong, so I can correct it.
I find the page title unfortunate, because "WikiPages" does not tell what the page is about, it too general. Better would be "Editing Guidlines" or ""Wiki Editing". However, since the page is hard to find anyway I would suggest to put a link with that name to that page into the sidebar just below "Tutorials". I believe one needs admin rights to do that.
gianfrancodp
Post by gianfrancodp »
I'm wanting to fix some errors in this page:
https://wiki.freecadweb.org/Import/Expo ... cOpenShell
For example at step 4 the correct command is
import sys
print (sys.paht)
I'm a new user, I can suggest to someone else these editing?
Thank you.
PrzemoF
Post by PrzemoF »
gianfrancodp wrote: Tue Mar 24, 2020 6:16 am I'm wanting to fix some errors in this page:
import sys
print (sys.paht)
Thank you.
Welcome to the forum! Take a look here: https://forum.freecadweb.org/viewtopic.php?f=21&t=6830
Baritone
Post by Baritone »
NormandC wrote: Wed Oct 17, 2018 4:52 am
qurn wrote: Tue Oct 16, 2018 1:08 pm Inconsistency:
- The section Usage is sometimes named "Usage", "Use" or "How to use". The "Template" https://www.freecadweb.org/wiki/Draft_Line says How to use.
I agree it should be "How to use". Unfortunately this change on a massive scale would invalidate a lot of translations on translated pages that have nonetheless a consistent naming scheme in their language. When I happen upon such pages I do change "Usage" or "Use" for "How to use", but I also immediately confirm the corresponding translations afterwards. This is very tedious, and requires admin rights.
I am a translator. Please, do not change "Usage" or "Use" for "How to use". "Usage" is becoming a new standard in fact on all updated pages. Let everything remain as it is.
Cekuhnen
Post by Cekuhnen »
hi all
sorry for asking - new to the wiki here
I would like to enhance few pages to make the workflow and limitations more clear to new users
example:
https://wiki.freecadweb.org/PartDesign_Fillet
add
limitations:
cannot do full round
show photos of errors
show photos of what works
show image of possible work around
there is some language present but it is so convoluted i even as a pro overlooked it
https://wiki.freecadweb.org/PartDesign_Plane
add
how to add datum tools to part design via adding macros to toolbar like for part design wb
this will be super useful and it is not clear to new users
https://wiki.freecadweb.org/Sketcher_Workbench
add
how to add sketch tools to part design via adding macros to toolbar like for part design wb
shall i just start the edit and submit or better have a discussion before?
MacOS Big Sur / Win 10
Designer | Faculty
Wayne State University
Interior - Industrial Design
Cekuhnen wrote: Mon Jul 26, 2021 2:20 pm shall i just start the edit and submit or better have a discussion before?
go for it!
Cekuhnen wrote: Mon Jul 26, 2021 2:20 pm https://wiki.freecadweb.org/PartDesign_Fillet
add
The first two: yes, go for it. The third: rather no, Then it should be added to all other workbenches such as Part, Draft too, but that seems far too special to me. The documentation is not a tutorial, where a certain concrete problem is handled.
Cekuhnen
Post by Cekuhnen »
chrisb i have to stop mult tasking i make currently to many mistakes
i was referring to adding a sketch to the part wb - it is already part of part design wb
the main idea here is to make it clear how the env can be customised to a more unified work flow for new users
Designer | Faculty
kaktus
Post by kaktus »
how about making a new valuable tutorial
Cekuhnen wrote: Mon Jul 26, 2021 3:56 pm chrisb i have to stop mult tasking i make currently to many mistakes
Good idea, do one step after the other.
You have to consider two things: abstract from your own models and targets, and you have to be very precise in your wording. There is no such thing as adding a sketch to Part workbench. Sketches can be added to models, tools or functions can be added to workbenches.
