Help doc not found FreeCAD compiled from master
NormandC
Post by NormandC »
Hello guys,
After compiling FreeCAD from master, I can't access the FreeCAD documentation (F1 or Help --> Help menu). Qt Assistant loads, but it reports the following error:
The page could not be found.
'qthelp://org.freecad.usermanual//../doc/Online_Help_Startpage.html'
In /src/Doc/freecad.qhc the file appears to be empty, it is no bigger than 64KB or so.
Any idea what would cause this? I have the same problem when building a debian package from the releases/FreeCAD-0-14 releases/FreeCAD-0-16 branch. http://freecadweb.org/tracker/view.php?id=2271#c6962
Thanks.
Edit: typo!
Re: Help doc not found FreeCAD compiled from master
No, problem here.
For me it's even less, it's ~8KB but that's OK. The help files are embedded into freecad.qch and this is >80MB.
NormandC
Post by NormandC »
I just installed FreeCAD 0.15.4671 from the Stable Releases PPA on Ubuntu 14.04 LTS.
I am getting exactly the same error as FreeCAD compiled from master, and from a deb package of v0.16.6700.
You really have no clue about this Werner? I'm at my wit's ends. :(
wmayer wrote:For me it's even less, it's ~8KB but that's OK. The help files are embedded into freecad.qch and this is >80MB.
I was not on my desktop PC when I wrote that. On the compiled version, I do have a freecad.qhc file of 8KB and a freecad.qch file of 82MB in src/Doc.
NormandC
Post by NormandC »
In FreeCAD 0.15.4671, I made the quick fix explained in that topic from last year: viewtopic.php?f=3&t=10606#p85440
And now the manual works in both the 0.15.4671 package and in FreeCAD compiled from master. I'm going crazy! :?
NormandC
Post by NormandC »
Ok, I found that the obsolete Startpage.html file was removed from /src/Doc/ some time ago (wasn't aware of that). But my debian/freecad-doc.doc-base was still referencing it.
That explains the error on my 0.16.6700 package, but not on compiled master. But I can't reproduce it anymore so I'll leave it at that.
I rebuilt a new 0.16 package and I had to create a debian/freecad-doc.install file with the following content:
src/Doc/freecad.qch usr/share/doc/freecad-doc
src/Doc/freecad.qhc usr/share/doc/freecad-doc
This time both qch and qhc files are written properly at install. It seems to work now.
Werner, once I am done with this I will try to send a merge request for an updated /package/debian folder. Then I guess we'll be able to close issue #2271 for good.
