Sezione Dinamica
Re: Sezione Dinamica
hi
single cube, i tray now the version not modified and i cause the same problem ??? certainly my configuration ??
i have upgrade the macro in the wiki
mario
mario
ciao mario,
I'd only tested it with some simple PDN things before I posted here. It certainly works for a simple cube for me. I should mention that I'm running a debug build. I do not know if that will make a difference.
However, I've been experimenting with more complex drawings, and the macro does actually have some more issues. For instance App.Part does not have a bounding box, so some more tweaking needs to be done.
I'll have a fool around with more over the next few days.
Hello, I don't understand this thread. But I came here from the Cross Section macro. It doesn't work with Freecad 0.18.3 and 0.19. There is not a window like this. When I execute it nothing happens.
OS: Windows 8.1
Version: 0.18.16131 (Git)
Branch: releases/FreeCAD-0-18
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.6
Qt version: 5.6.2
Locale: Italian/Italy (it_IT)
Hi leoheck,
I must confess I'm new to FreeCAD, but I had the same issue and I wasn't able to find any solution googling. I managed to fix it by adding the following line:
self.oblist = [obj for obj in self.oblist if hasattr(obj,"Shape")]
# Make a list of the user's objects
# WARNING!!
# This list is persistent. We'll get confused if the user deletes or
# adds objects while the macro is active
self.oblist = App.ActiveDocument.Objects
# Create the cross-section object
My knowledge of the FreeCAD APIs are zero but i figured out that it has something to do with the listing of the objects. In fact most of them don't have a "Shape" attribute.
OS: Linux Mint 19
Version: 0.18.3.
Python version: 3.6.8
Qt version: 5.9.5
@g.becu I didn't see it before. Cool, your solution fixed this issue. Thank you dude!
I need to know how to submit this to the maintainer of this macro.
Saluti
fato Macro_cross_section grazie g.becu e benvenuto
ver 00.09 31/08/2019 : upgrade by g.becu adding line 334
mario
mario
I wondered if anyone had extended this useful
macro, so that an arbitary face can be selected
and the unit normal used to define the plane of the
section?
Best Wishes
section?
Best Wishes
salve, mario52 protesti fare una piccola guida come si creano le macro con la gui e anche quelle senza.mario52 wrote: ↑Sat Aug 31, 2019 10:28 am Saluti
mario
perché sto leggendo la guida di onekk .. ma lui parte dai file .py, ed invece tu parti dai file ..FCMacro.
Hai qualche guida al riguardo oltre ad quella di onekk.
salve
(FCMacro e usato per distinguere una macro dedicata per FreeCAD)
ma se fate un import miofile il file "miofile" da importare deve avere l'estensione "miofile.py" sino non funziona perché diventa uno file Python
su la mia segnatura avete qualunque pagine interessante ma non tutte sono aggiornata
(select a face and the "cut" is operate by its normal ? )
mario
potete rinominare .py in .FCMacro sonno tutti e due lo stesso per FreeCAD
more explanation or image example
mario
