Sezione Dinamica
Re: Sezione Dinamica
Hi Mario, I'm continuing the threadmario52 wrote:ciao
ho modificato l'originale della macro ho aggiunto uno chekbox que permette di conservare la sezione
la macro originale serve solo per la visualizzazione
mario
viewtopic.php?f=3&t=18046#p141860
here, also if I consider a pity because in a language subforum will have less visibility...
Anyway here my query:
It would be possible to have the macro conserving the colors in the cutted section?
Thank you
Maurice
saluti
I do not know
currently the macro create a single object and takes just a color
it would make a normal copy ... can try ?
mario
I do not know
mario
Ciao Mario,
penso che potresti mettere anche la tua versione della Macro Cross Section nel wiki, oltre al link
Renato
Renato
Mario,
I see from some of the posts in this thread that you speak English. Lucky for me!
I ended up here from the wiki article Macro cross section.
I am unable to locate the original author of the macro, and so you seem to be the maintainer by default
I think it needs a small tweak to work with FreeCAD 0.17. Around line 340 you'll see it skipping uninteresting objects. 0.17 seems to have introduced "GeoFeature" which causes the macro to fail.
After changing the code as above it's working fine for me.
############################# Skip the <group object> ######################## # add
b0 = []
for x0 in self.oblist:
if ( str(x0) != "<group object>"
and str(x0) != "<GeoFeature object>" ):
b0.append(x0)
saluti
grazie per alepho ma FreeCAD si chiude con o senza la modificazione
thanks for alepho but FreeCAD close with or without modification
OS: Windows 10
Version: 0.17.11749 (Git)
Hash: 6c4bdf24dfd697ee212ec5950969125851a0907c
Python version: 2.7.8
Qt version: 4.8.7
OCC version: 7.1.0
OS: Windows 10
Version: 0.17.11797 (Git)
Hash: a5080329d8da6653495df686efbda62e73ac950a
Qt version: 4.8.7
OCC version: 7.1.0
mario
OS: Windows 10
Qt version: 4.8.7
OCC version: 7.1.0
OS: Windows 10
Qt version: 4.8.7
OCC version: 7.1.0
mario
Works for me...
OS: Ubuntu 16.04.3 LTS
Version: 0.17.11792 (Git)
Build type: None
Hash: 7aec98ffb66065854a66d6d6715845fdbf0869a7
Python version: 2.7.12
Qt version: 4.8.7
OCC version: 7.1.0
- Macro_cross_section.FCMacro.zip
- (5.46 KiB) Downloaded 326 times
Saluti Sam
on Window, not work
OS: Windows 10
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Hash: f86a4e411ff7848dea98d7242f43b7774bee8fa0
Qt version: 4.8.7
OCC version: 6.8.0.oce-0.17
OS: Windows 10
Qt version: 4.8.7
OCC version: 7.1.0
mario
on Window, not work
OS: Windows 10
Qt version: 4.8.7
OS: Windows 10
Qt version: 4.8.7
OCC version: 7.1.0
mario
Tested with a cube. It works. I do not know with more complex objects.
Provato con un cubo. Funziona. Non so con oggetti più complessi. OS: Windows 8.1
Qt version: 4.8.7
Renato
Qt version: 4.8.7
Renato
