[solved] cannot save null image, what's wrong
godblessfq
Post by godblessfq »
Hi everyone,
I got this error when I try to save a screenshot.
 <unknown exception traceback><type 'exceptions.RuntimeError'>: Cannot save null image.
I think the script the screenshot button runs is:
Gui.activeDocument().activeView().saveImage('/home/q/Downloads/5.jpeg',733,410,'Current')
I have the latest 0.16 develop edition
OS: Debian GNU/Linux 8.0 (jessie)
Version: 0.16.5841 (Git)
Hash: e7d16c5f620bc4ddded8b8eae97d6e29c0012490
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 6.7.0
jmaustpc
Re: cannot save null image, what's wrong
Post by jmaustpc »
godblessfq wrote:I think the script the screenshot button runs is:
I just tried the code you posted, obviously changed the directory, but then it worked for me.
OS: Ubuntu 14.04.3 LTS
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
godblessfq
Is it because of my GPU? I am using the Fujitsu t580 laptop. It's a pretty new model in 2010.
jmaustpc wrote:two common ways are either tools menu "save picture" which saves a jpeg file of the current view in the model window or use a screen capture application which can take a picture of anything displayed on you screen.
Note that the first one only works if your GPU and its driver support it. Most should, but some pathetic old GPUs do not and some drivers may not implement the feature even when the hardware would.
godblessfq
If I run the command in the console, a pop up appears and says "unhandled pycxx exeption"
godblessfq
BTW, what is the pythonic way of refer to a sub object?
I have seen two styles:
1 Gui.activeDocument().activeView().saveImage
2 Gui.activeDocument.activeView.saveImage
The second looks better to me.
jmaustpc
Post by jmaustpc »
godblessfq wrote:Is it because of my GPU?
In the past GPU or its driver has been the problem.
At one time a while ago, I had a Nvidia GPU and found it worked with either opensource or the proprietary drive but not the other.
Most of us use a independent the screen capture application most of the time.
godblessfq
The same image tool works in an old version install with apt-get on the same machine. Weired.
Word size: 64-bit
Version: 0.14.3702 (Git)
Branch: releases/FreeCAD-0-14
Hash: b3368125c63289ec8ce9faec2b2ae4c78d436406
Python version: 2.7.8
Qt version: 4.8.6
SoQt version: 1.6.0a
OCC version: 6.7.0
godblessfq
Here is the solution, just need some digging. :)
wmayer wrote:As you solved the issue while I was typing I decided not to reject the content in case someone else has a similar issue.
Open the parameter editor and go to the group: Preferences > Document:
1. There create a boolean key DisablePBuffers and set it to true. Try again.
2. If it doesn't work set the value to false. Try again.
3. If it doesn't work create the boolean key CoinOffscreenRenderer and set it to true. Try again.
4. If it doesn't work then close FreeCAD and set the environment variables:
COIN_GLXGLUE_NO_PBUFFERS=1
COIN_GLXGLUE_NO_GLX13_PBUFFERS=1
Now restart FreeCAD and try again.
FreeCADUser1
Re: [solved] cannot save null image, what's wrong
Post by FreeCADUser1 »
Remote desktop issue
Interestingly, I saw differing behaviour between 0.14 and 0.17 on win7 over remote desktop
while sat at the win7 machine (local) with both versions installed, I could save images with no problems in both versions of Freecad.
(simple box generated from new)
However, remotely..
I could only save images (several file formats) using 0.14
Using 0.17 - I got an error
<unknown exception> cannot save null image
I tried both the suggested Boolean operators, DisablePBuffer and CoinOffRender, both had no effect.
I'm guessing the remote OS is selecting different graphics cards when running the different versions (0.14 and 0.17), but have no idea.
Hard to determine which card is being used as I have an intergrated GPU card(s) with no control options (unlike NVidia)
Intel HD 4600 and AMD Radeon 8750A
I also tested the 32 and 64-bit versions, and had the same result.
As a workaround for 0.17, the print screen command works.
fosselius
Post by fosselius »
I get this issue with 0.18 appimg and are unable to solve it with the steps above, i have an intel based laptop, no dedicated graphics
OS: Ubuntu 18.10
Version: 0.18.15611 (Git)
Hash: 64a94ae0f7c60fc981086fe157150a9c0dca29c6
Python version: 2.7.15+
Qt version: 5.11.1
