ThanksAnd specially for Xav-83 just make a new plugin for Grbl card...
Arduino PySerial USB Connection
Re: Arduino PySerial USB Connection
- 2015-10-24-165817_478x460_scrot.png (22.7 KiB) Viewed 4915 times
https://github.com/Xav83130/Mini-CNC
Tuto FR-basic -PATH - https://github.com/Xav83130/Mini-CNC/wi ... Basic-Path (plus a jour)
Hi Xav-83,
Thank for the info...
I understand for $$, but for $# what is the command for changing a parameter like [G58:0.000,0.000,0.000]...
I need to know the syntax...
edit: can you confirm that you can upload file with the new plugin... I am not really sure...
for change parameter of $# it seems to me that it is with the G10 command.
I never had occasion to use it
G10 Programmable data input --> Modifies the value of work coordinate and tool offsets.
Wiki grbl
When I upload a file, I can't see the toolpath in freecad. I can not confirm to you whether it is the correct file.
However,
1 I charge one of my files.
2 I made a "Home"
3 I put my tool in origin parts
4 G91 X0 Y0 Z0;
5 I run machining
6 the truck from too far out of range of the machine.
PS: internet traduction ... sorry i speak very little english
Wiki grbl
G54-G59 work coordinates can be changed via the G10 L2 Px or G10 L20 Px command defined by the NIST gcode standard and the EMC2 (linuxcnc.org) standard. G28/G30 pre-defined positions can be changed via the G28.1 and the G30.1 commands, respectively.
When $# is called, Grbl will respond with the stored offsets from machine coordinates for each system as follows. TLO denotes tool length offset, and PRB denotes the coordinates of the last probing cycle.
However,
2 I made a "Home"
4 G91 X0 Y0 Z0;
5 I run machining
But It's a good way to learn ...
Whith TinyG2 it look like: "posx:12.086,posy:0.453,posz:0.000,feed:300.00,vel:300.00"
But IMO, if we want to integrate this feature, need some help because what I do is just crap (but just to see that it was possible ...)
I hope someone will hear us...
And have integrated the $$ command... You can test and say...
Ok i need to send GCode command... and I need to learn because I am a beginner...G54-G59 work coordinates can be changed via the G10 L2 Px or G10 L20 Px command
I have not integrated the "toolpath" in the Grbl Plugin because I don't know the format of the positions received from Grbl while uploading...When I upload a file, I can't see the toolpath in freecad
Ok, I just remake file upload. Now I hope it's more reliable...I can not confirm to you whether it is the correct file.
As per my experience with these things if you are going to attempt a Controller Workbench for 3/4 axis control, you must take the interface along the lines of GRBL Controller.
Also this kind of interface within a FreeCAD module and able to work hand in hand with Path, would be a great well rounded package Path / Controller.
It might have to remain separate from FreeCAD due to the license, (GPL3), though I can never keep those things straight, what's compatible, what is not.
Hi HughTufano
Your first post, welcome to FreeCAD.
yes, it complicates matters.HughTufano wrote:due to the license, (GPL3),
Hi HughTufano,
Welcome to FreeCAD Forum...
it would be good to have a generic core and make a plugin for each card (Grbl, TinyG2...)
I have to work on that, any help is welcome
it would be better to start from scratch, if we want to manage other card than Grbl like TinyG2...if you are going to attempt a Controller Workbench for 3/4 axis control, you must take the interface along the lines of GRBL Controller
I have just installed FreeCad and I would like to control my Arduino using this amazing program. However, I currently have an Arduino Due, and i'm having this error.
Running the Python command 'Usb_Start' failed:
File "/home/bava/cad/freecad-build/Mod/USB/App/UsbCommand.py", line 152, in Activated
FreeCADGui.doCommand(code)
File "<string>", line 2, in <module>
'FeaturePython' object has no attribute 'Start
Thank you
Thank you
@prrvchr ping
